Old 01-21-2004, 01:56 PM   #1
68 Suburban
68 Suburban's Avatar
What kind of lube do I use for my Rearend?
Not vasaline or KY.....
I noticed that there are basically 2 weights of gear lube. 80w90 and then there is a 85w140. I know the 80w90 will be better for the mileage, but will it offer enough protection?
I do plan to use a synthetic gear lube, so maybe the protection worry is not a problem?
Also, How many quarts do I need for a 12 bolt? Thanks
68 Suburban is offline   Reply With Quote
Old 01-21-2004, 02:07 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I alway have used 80w90 here in cold country. Last time I did this I bought 3 qts and used a little over 2.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-21-2004, 02:08 PM   #3
MrShelley
Too Many Clubs Club
MrShelley's Avatar
The title of this thread is just ASKING for trouble! LOL
MrShelley is offline   Reply With Quote
Old 01-21-2004, 02:09 PM   #4
cdowns
cdowns's Avatar
80/90 is the weight to use takes about 2quarts
Old 01-21-2004, 02:10 PM   #5
68 Suburban
But, it got you to read the thread
Old 01-21-2004, 03:20 PM   #6
71Chev
71Chev's Avatar
After I change the fluid I take it for a short drive and I check the level again, usually takes just a little more to top it off again.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 01-21-2004, 05:45 PM   #7
Ole Blue
I'd check with the doctor on this one!
72 Cheyenne Super waiting on 4/6 drop,BB and 700r4
Ole Blue is offline   Reply With Quote
Old 01-21-2004, 05:54 PM   #8
rage'nrat638
rage'nrat638's Avatar
vasaline or KY.....
be a man.....use some SPIT
rage'nrat638 is offline   Reply With Quote
Old 01-21-2004, 05:55 PM   #9
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
80-90w here also. No synthetic.
67Fleetsidedream is offline   Reply With Quote
Old 01-21-2004, 07:01 PM   #10
cochino12
It followed me home?
cochino12's Avatar
Originally posted by rage'nrat638
vasaline or KY.....
thats funny
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-21-2004, 07:27 PM   #11
68 Suburban
All done lubing the rear. And might I say, my rear looked damn good
Old 01-21-2004, 08:37 PM   #12
bow-tie-bandit
Live life and be happy.
bow-tie-bandit's Avatar
I'll stay away from this one.
bow-tie-bandit is offline   Reply With Quote
Old 01-21-2004, 09:53 PM   #13
Blue Beard
Blue Beard's Avatar
Why stay away from it, he just keeps asking for it................
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-21-2004, 09:57 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I use 80/90 valvoline..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-21-2004, 11:01 PM   #15
CG
BlahBlahBlah
now thats a bad case of hemroids
Old 01-21-2004, 11:18 PM   #16
67gmcss
one person said no synthetic....any reason, or just preference?
67gmcss is offline   Reply With Quote
Old 01-21-2004, 11:34 PM   #17
68 Suburban
I think he was just stating what was in his, not condeming synthetic.
Old 01-21-2004, 11:41 PM   #18
rage'nrat638
i would not just go use synthetic in a 30 year old, plus rear end with out putting all new seals in....
it's much thinner like motor oil and you are sure to get leak's...
synthetic is supposed to be the hot ticket for race rear ends..
less power loss....less wear.....
but in a old truck?????8.00 a qt.!!!!!!!!no new seals...i won't
Old 01-22-2004, 01:18 AM   #19
68 Suburban
To late, and it was only $6.99 a quart Those rumors of synthetic wiping out seals have been around for a long time. I have never had a problem in any older vehicle that I have run synthetic products.
Old 01-22-2004, 01:21 AM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I swapped my rear over to synthetic too, and haven't had any problems.
I think the axle seals on my truck ar ethe only seals that DON'T leak.
Old 01-22-2004, 01:28 AM   #21
dinnut
dinnut's Avatar
its true that it is the only seal that doesnt leak, or at least on my truck
my oilpan, my rear main seal, my ps gear box, my tranny, all leak but not my rear end!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-22-2004, 01:30 AM   #22
djracer
djracer's Avatar
If its a posi don't forget to add the additive for the clutches!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-22-2004, 01:31 AM   #23
MJN
MJN's Avatar
I've never had a problem running synthetic and in rear ends and transmissions (manuals of course). I always check the manuals I have before changing fluids too just to get a good idea of how much to get and what weight. Usually 80w90 for rears, fronts and trannies. If you have posi, always run the GM additive, never had any problems with that stuff, it's a little spendy but it really works.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 01-22-2004, 01:37 AM   #24
68 Suburban
My rear is not a posi, but what I have read, it has the additives in it
