Old 01-21-2004, 05:14 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Best way to drain gas
Well I am back, and I haven't started my truck in nearly a year. What is the best way to drain the gas out. Also I will pull the distro to prime the engine of oil. If any one has any other helpful hints on what to do to get it running safely again after a long sleep please feel free to drop in a comment.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 01-21-2004, 05:32 PM   #2
Paul72
Paul72's Avatar
Welcome back!!! It must feel good to be back stateside again! Are you done with the middle east, or is there a chance of a second tour?
How much gas is in your tank? If it has been sitting for a year, I would drain it to about half, and put in some fresh stuff - then go out and burn it up!. Siphon hose worked for me in the past.
Check the dizzy cap, rotor, points (unless HEI) and make sure it's all clean.
Maybe pull the plugs and squirt a little oil in the cyl's and turn the motor over.
That's all I can think of for now..
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 01-21-2004, 05:36 PM   #3
JayDubBlazer
go cyclones
Really not sure how much is left, but being a college student I am sure it is less than a half tank. It is an HEI so I don't have to worry about that. I might Have a chance to fool around with it this weekend if I can finish moving back in to my house. My roommates weren't expecting me back until April so I kinda just showed up, need to reclaim my room.
And no there shouldn't be any chance of me going back over there, just as long as I can escape the "Stop Loss". After Bosnia in the Active Army and Kuwait/Iraq in the National Guard I think I am done.
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 01-21-2004, 05:40 PM   #4
Paul72
Paul72's Avatar
I would just fill the tank and put 2-3 bottles of HEET in there to suck up the moisture and it should be fine.
Old 01-21-2004, 08:49 PM   #5
1970blazin
Blazerless:-(
1970blazin's Avatar
JayDub!! Good to see you're back safe and sound! Good luck with the blaze! Bet you were glad to see it! Maybe we can get some pics from you finally!
Diane
1970blazin
1970 CST Blazer-Orig. Dark Blue-SOLD
Progress Pics of Blazer for sale
1970blazin is offline   Reply With Quote
Old 01-21-2004, 09:46 PM   #6
Blue Beard
Blue Beard's Avatar
Drain the gas..........use the Oklahoma credit card................
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-21-2004, 11:33 PM   #7
blazer1971
Go to a marine store. They deal with stale gas alot in the boating industry. Something called seafoam or a similar product will revitalize your gas.
good luck
blazer1971 is offline   Reply With Quote
Old 01-26-2004, 11:48 AM   #8
mister.freeze
mister.freeze's Avatar
deployments
Hey! I was in Bosnia for SFOR 6 and got bac from Kuwait las Jan: USAR. I had to let the Fox sleep for both deployments. The key to a good sleep is prep. As far as resurrecting your truck, all the fuel suggestions are good. Marvel Mystery Oil in the cylinders is a good idea. Pull your main wire from your coil and cracnk for a little while (don't burn up the starter) to get oil throughout before firing it off. Make sure you've got ALL your flids too: It would suck to drive for the first time and the brakes or pwr steering don't work, or you overheat. Once it's running again, a prompt oil change and at least a tank of premium should clean out the insides. Welcome back!
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
