Old 01-21-2004, 08:11 PM   #1
theo70
COMING SOON...
theo70's Avatar
disc conversion woes
I'm in the middle of the swap, and as soon as I finally got these $#@%&* ball joints loose, I see the fitting on the brake line is smaller than the threads on the new hose. I have the upgrade kit from CPP with the 73-87 balljoints & tie rods--is that why?
So, would it be better to cut & "re-flute" the line with a new fitting, or get a whole new line?
theo70 is offline   Reply With Quote
Old 01-21-2004, 09:17 PM   #2
zenish
i adapted my lines on my master cylinder with adapters from pep boys.
zenish is offline   Reply With Quote
Old 01-21-2004, 09:29 PM   #3
1972C10
1972C10's Avatar
Friend of mines truck ran into the same problem we just got a reducing coupler i think it was 1/4- 3/16 we just took the old brake line in with a peice of the new one and got a coupler that worked
1972C10 is offline   Reply With Quote
Old 01-21-2004, 09:40 PM   #4
rage'nrat638
rage'nrat638's Avatar
yup doing the same thing....
these fitting adaptors are easy to get...got mine at lee's auto parts....
nobody said it was easy
rage'nrat638 is offline   Reply With Quote
Old 01-22-2004, 07:50 AM   #5
theo70
COMING SOON...
theo70's Avatar
Ah, OK. When you guys say "couplers" & "adapters," do you mean a union that has two different size threads on it? I haven't heard of those yet.
Thanks -- sounds alot easier than replacing stuff.
Old 01-22-2004, 08:13 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
When I ran into that, I just bought the hoses from Early Classic Enterprises. They sell a special adapter brake hose that has the proper fittings on each end.
