Old 01-21-2004, 08:24 PM   #1
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
Will Coil Springs from a V6 C-10 Drop my truck
I am assuming they had different front coil springs for V6 vs. small block V8s vs. big blocks.
If so, how much.
I am having trouble finding 1" springs to go with a 2.5" spindle for a 3.5" drop.
I am going this route because I want new springs anyway to level out my truck, and 2.5 spindles so that I can run stock 15X8 rallys without any worries of rubbing.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 01-21-2004, 08:45 PM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb
The spring's have different spring rate's for the weight of the V6 & V8 the spring's will physically fit but the truck will probably bottom out when you hit a big hole or dip in the road.
I don't understand why you can't find dropped spring's. There must be at least 6 company's that make a spring to fit your truck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-21-2004, 08:51 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
I would go with a 1.5" spring. I'm not sure they even make 1" drop springs or not.
Why are you set on 3.5" of drop?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-22-2004, 11:40 AM   #4
8t5Silverado
I was wondering about bottoming out. I thought the V6 springs might give me the same look and ride, but cheaper...
Mike, I am not set on 3.5. I just want to be able to still get up my driveway.
It does me no good to have a truck with the right stance that can't make it into my garage.
I think I will go with the 1.5 springs and 2.5 spindles from Western Chassis with a flip in back...
Thanks.
Old 01-22-2004, 02:24 PM   #5
bigblock73
yeller
bigblock73's Avatar
Last time I checked, 1" Bell Tech drop springs were around $109,
bigblock73 is offline   Reply With Quote
