01-21-2004, 08:25 PM | #1 |
yeller
E-brake mechanism rebuild
Has anyone here taken apart their E-brake mechanism or rebuilt theirs? I want to take mine apart, but it does not appear it is possible since it looks like the moving parts are pressed in with some kind of pins or clips of some kind. I am sure I could beat it apart, but getting it back together might be alot harder.
Thanks!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-21-2004, 08:49 PM | #2 |
Gentleman Jim Driver
I paid $30 for a brand new GM part for my 84.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
01-21-2004, 09:05 PM | #3 |
yeller
Joe, is it identical to my 73 pictured above? When and where did you purchase it?
01-22-2004, 02:00 PM | #4 |
Ever thought about going with a hand brake?
I have a manual trans so I already have stuff there. I thought about going with something like this because I like the hand brakes so much more then the foot brakes. http://www.jegs.com/cgi-bin/ncommerc...17&prmenbr=361
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
01-22-2004, 05:16 PM | #5 |
Available for Adoption
LMC has them for $39 if I recall, might also check with the dealer....
1983 C10 SWB 2001 Silverado SWB 1995 Corvette |
01-27-2004, 01:18 AM | #6 |
yeller
OK folks, I need some help.
I called my local dealer, and he ran the part in his computer...it turns out the part is discontinued. The part is called e-brake pedal or e-brake pedal assembly, and the GM part number is 362280. I asked if it was the same as the 80's model and if it was interchangeable...he said if it was interchangeable (and still available), it would show up on the system. Now keep in mind he did a search for a 1973 C10...I did not ask him to search for a 1985 or whatever, so I cannot verify they are the same for all years. Joe, can you post a pic of yours you just purchased? I would like to see if they are indentical or not. Also, I need the front e-brake cable (the one that attaches to the mechanism), and that too is unavailable (I did not get a part number). Would someone outside MN be willing to try their GM dealer to see if they can find or get these? When inquiring, please be sure to tell them it is a 73...that way I KNOW I am getting the correct part. If it turns out someone can get these two things, I would really like to get them and would like to work out arrangements to do so. Thanks!
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 01-27-2004 at 01:23 AM. |
01-27-2004, 02:13 AM | #7 | |
Here are two pics. Jeff, if you want them bigger, I'll send them to your email.
01-27-2004, 02:52 PM | #8 |
Mudslides 'r my specialty
How do you know if this part needs replacing or if you simply need a new cable alone....
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
01-28-2004, 04:28 PM | #9 |
So did those pics work for you Jeff?
01-28-2004, 04:37 PM | #10 |
yeller
Joe, it does look identical...I am going to try and call the dealer again and see if they have one for a 85 or whatever...and see what they come up with.
If they can't help, would you mind seeing if the dealer by your house tells you the same story? Check first for a 73..but if they say no see if they have a 85. I might need a couple measurements when I get home, just to be sure they are the same size and what not. I'll let you know. Thanks again Joe for the pics and help!
01-28-2004, 05:00 PM | #11 |
www.73-87chevytrucks.com
Based on tearing these apart, they should all fit yours Jeff.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-28-2004, 05:25 PM | #12 |
if anyone wants a good used one let me know $10 plus ride i have one out of an 76
i haveswapped a 76 to an 81 body and they seem to be all alike |
