01-21-2004, 09:15 PM | #1 |
Before and After
Ground strap
Is there supposed to be a ground strap from the bed to the frame?
I am having problems since I removed the bed, and rewired the rear harness. The problem is: once I have the side marker lights grounded, I have power to the bed, when I check with a test light from the frame to the bed. I know that is not right. The harness was suspect #1 and it checked out OK. If I ground the marker light to the frame, it lights up. What would you check?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
01-21-2004, 09:23 PM | #2 |
Before and After
When I Ground the bed to the frame, It works.
Can anyone tell me howlong of a strap that is required and it's location?
01-21-2004, 09:29 PM | #3 |
If in doubt, add one......can't hurt anything.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-21-2004, 09:36 PM | #4 |
Wiseass secured himself a BAN
I would think that the bolts holding the bed to the frame would be a adequate ground. Like he said above. Add one it won't hurt.
01-21-2004, 10:39 PM | #5 |
Before and After
I think that I know what happened.
When I re-installed the bed, I put a rubber gasket inbetween the bed and frame to stop the squeeking that was there in the past. The bolts are not tightened to the frame yet so the box isn't really touching the frame and the bolts arent either. I think that I will install one just to be safe. Thanks for the help.
01-21-2004, 10:59 PM | #6 |
I'm dealing with the same prob. I painted my frame and when I put the bed back on I forgot to clean a spot to bare metal. Now when I hit the brake all the lights come on. Rather than unbolting the frame again I just added a ground strap.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
01-21-2004, 11:06 PM | #7 |
PROJECT 7DEUCE
Had the same thing happen to my truck and when I added the ground strap it fixed all my problem's..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-22-2004, 01:02 AM | #8 |
Before and After
I'm glad I'm not the only one with this problem.
Oh Ya, its FIXED.
01-22-2004, 01:07 AM | #9 |
its all about the +6 inches
Beds with wooden floors are more likely to have this problem, but there is nothing wrong with adding a ground strap...or two.
I go over board with ground straps and ground wires...but I never have ground problems either. |
01-22-2004, 01:11 AM | #10 |
Merciless Butcher
Grounding Strap
Grounding problems can be the worst. I've had the same problems in the past. Summit sells these braided grounding straps. They're really cheap (around 5 bucks). And really do the trick.
Your Bought And Sold....I Got Your Soul! |
01-22-2004, 01:32 AM | #11 |
wow, gonebad those look great! ill have to look into some of those
70 longbed 496/th400/Ford 9" |
01-22-2004, 02:37 AM | #12 |
My other Love
I have seen that Napa or Lordco if you are IN BC always has them
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
