Old 01-21-2004, 10:19 PM   #1
CRUMP68
1967 3-Speed for 67 C-10 6cyl. ?
Wanted to buy 3-Speed for 67 lwb C-10 6cyl.
The one on it measures 16.5 inches long. I found one but is 20.5 inches long. I live in Ashland Ky. There Hard to find here for some reason.
CRUMP68 is offline   Reply With Quote
Old 01-22-2004, 01:04 AM   #2
whitesswj
Embrace the Redneck
whitesswj's Avatar
I might be buying a 67 c10 soon (as in with in 2 to 3 weeks). email me @ whitesswj@squaredc.net I'll check it out for you!!
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 01-22-2004, 03:07 AM   #3
Crank
Crank's Avatar
There's one down in Richmond KY, at my old house. Call my buddy Adam at Ado's/Detherages Salvage, and have him pull it to his junkyard, then pull it there. You can have it. I need to get down there and get my vin plate and some tires off it.
Brandon
Crank is offline   Reply With Quote
Old 01-22-2004, 11:09 AM   #4
CRUMP68
Ok thank you both for the info.
Old 01-22-2004, 12:15 PM   #5
mnick
I have a 3 spd trans from a small block, but it has a transfer case behind it. I need the transfer case, but I don't need the trans.
come get it and you can have it. you need a tail shaft housing at the very least to convert it to 2wd. I don't know if the output shafts are the same or not.
mnick is offline   Reply With Quote
Old 01-22-2004, 05:30 PM   #6
Crank
Crank's Avatar
PM me sometime and I'll have to give the guy a call.....
Brandon
