Old 01-21-2004, 11:39 PM   #1
roempty
lighting problem 86 gmc
slight problem when I turn on headlights I have no parking lights or blinkers .head lights off the work fine.maybe new wiring .i;m getting new insterment cluster thought that could be problem
roempty is offline   Reply With Quote
Old 01-22-2004, 12:58 AM   #2
crackajacka
Stylin
crackajacka's Avatar
wireing problem.
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 01-22-2004, 02:12 AM   #3
shavedchevy
shavedchevy's Avatar
Sounds like you have a lot of work to do. This happed to me once and it to the beter part of 6 hours to completely fix the problem. Some adivce if the wiring is screwed, make sure sure you reattach the right wires together.
But this sound like you have a single filament bulb in somewhere, this is what I had. Taillight wiring is a very complicated set up.
Dennis
shavedchevy is offline   Reply With Quote
Old 01-22-2004, 02:23 AM   #4
crackajacka
Stylin
ok check the bulbs then if its still that check the sockets they tend to get loose. and if all else fails u can always buy wire and re wire the front lights. thats basically all that was wrong with mine.
Old 01-22-2004, 05:48 PM   #5
roempty
Thanks for the help.I found that someone added trailer lights and reversed them going to tail light and blinker .all is bright and blinking in my world
