Old 01-22-2004, 03:19 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Removeing Heater Houseing Non A/c
I know one lady from this board did it and had very great visual aid...I know I can do it....BUT...I have one question about the nut and bolt above and to the back of the fender well on the firewell.
On the inside the end is bent over and flat...is it removeable, by say cuttin this end of with like a dremel cutting wheel?? So I never have to deal with it ever again??? Just curious. I'll get a pic so we are on the same page.
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 01-22-2004, 04:09 AM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
Heater Stud
I am a little unsure about which bolt you're talking about. Is it the black stud that is attached to the inner heater box and pushes through the firewall? Pictured is the heaterbox that mounts in the engine compartment. If you have a pic, please post it....Thanks
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-22-2004, 05:06 AM   #3
SWINGSAX68
SWINGSAX68's Avatar
Yes that one....I meant stud...well the back of that stud is bent over and flatened against the inner heater box. This one here in this pic...
Can I use a cutting wheel and hack it off then push the stud out???Then of course I would just run a large sheet metal screw from the inside to the outside....hence no longer haveing to fuss with that stupid nut on the fire wall???? I'm gonna try it anyways....just need a dremel and cutting wheel.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 01-22-2004, 05:08 AM   #4
SWINGSAX68
SWINGSAX68's Avatar
one more
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 01-22-2004, 05:43 AM   #5
gonebad2
Merciless Butcher
gonebad2's Avatar
Yeah, you should be able to grind it off from the inside. I think in 1970, GM switched from a metal interior box to plastic. It will be alot easier for you if it's metal. Dropping the inner fender can be a real pain. Be careful when you pry the heaterbox off the firewall when accessing the heater core. That box is made of fiberglass and they are pretty brittle. I see alot of them in the junkyards where the mounting flanges are broken.....Good Luck
Old 01-22-2004, 11:30 AM   #6
SWINGSAX68
SWINGSAX68's Avatar
gonebad2,
Hey I noticed above that you used a regular spade connector on the heater motor wire....do you want the end with the rubber boot that slips over that rubber part??? I have one laying around that I don't need. Unless you specifically did not want that little boot...it is a pain sometimes to get off. I'll take a pic if your interested.
"F#$@ 'em up!!!!!!"
TRUCKY LINKS
Old 01-22-2004, 04:15 PM   #7
oldsub86
Why not just drop the inner fender? I have done it several times - never any real problem.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
