Drum Brake Question
After 53K miles on the Kevlar front shoes, they have a little life on them, but I feel it is time for replacement. Not bad, especially considering all the towing I do with my burb.
My question is, the secondary (back and larger) shoe seemed to wear more than the primary (front and smaller) shoe did. Is this normal? The wheel cylinder is not leaking at all, but could it be hanging up? Or is this a normal wear pattern. Thanks |
I"m not sure if thats normal or not
![]() I;m only 13 and don't know too much about brales but that would seem logical to me watching my dad do it twice!! My logic isn't the best though so you might want to ask some other people ![]()
(Only) Member of the CPNE Fan Club ![]() ![]() 67 C-10 350 with 3-speed tranny and 308 gears swb step ![]() 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
I did put a brand new heavy duty spring kit on when I did the brakes last. I didn't grease the contact points on the shoes though
its all about the +6 inches
I have seen that happen quite a bit, so i would say it is normal...at least not uncommon anyways.
how long did you run these...seems like you just installed these shoes. |
#5 | |
If both are wearing the same, you have no stoping problems, no noise, etc, I would say you have no problem. A little wheel bearing, or white lithium grease, whatever you have handy is fine. the key word is a "little" grease.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
#7 | |
I always use anti-seize compound on the backing plate on the contacts.
Out of the carpool lane.
My 'normal' brakes wear like that too so I think you're okay. Btw, did you buy their stage III kit or just the shoes and springs? I may buy the kit soon for my Camaro as it needs new brakes bad.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#10 | |
