01-23-2004, 03:28 AM | #1 |
Before and After
Factory bench Question
The rigid wire that connects the two sides of the mounting brackets has been taken off.
I want to put it back on, I think I remember that it went through some hog rings, is that true? If so how many? The wire is too long if it doesn't. I know that I don't need it if I don't want to adjust the seat, and Iprobably won't adjust it, I would just like it back on. Photos?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
01-23-2004, 04:03 AM | #2 |
Merciless Butcher
That sounds right. The hog ring was used to keep the wire up and out of the way.
Your Bought And Sold....I Got Your Soul! |
01-23-2004, 04:15 AM | #3 |
Actually there should be a small metal loop attached to the bottom of the seat springs midway across the bottom of the seat that it slides through before connecting on either side.
GMCPaul |
01-23-2004, 10:44 PM | #4 |
Before and After
Does it go through just one hog ring?
01-24-2004, 12:06 AM | #5 |
Mine goes through only one hog ring...if it still has too much slack to adjust the seat back and forth, put it through another hog ring.
