Professional Grade
6x9 brackets for the cab corners?
Does anyone sell these? I want a setup that looks fairly stock to ward off any theifs when I buy some nice expensive 6 x 9s as well as door speakers.
Also - Does anyone know if they make delete plates for the stereo hole on the aluminum brushed dash bezels?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
take a set of stock 4x10 brackets, and flip them, drivers side to passenger, passenger to driver. then you should be able to clearance them for 6x9s, or so i've heard. as for door speakers, dont do it! mount a pair in the dash where they belong.
Are 6x9s that much better than 4x10s?? Reason I ask is because I picked us a set of the brackets at a bone yard with the factory 4x10s (they're shot) and was going to replace them with 4x10s...but if 6x9s are better, then,....
ken '58 Chev NAPCO 4x4 short '60 GMC Suburban 4x4, restored '60 GMC 3/4T stepside 4x4 '64 GMC Suburban 4x4, restored '90 Chev Suburban 4x4, dually, ZZ502 '77 GMC Suburban 4x4, one ton axles, 12" lift, 39.5"s '88 Chevy crewcab dually 4x4, 10" lift, 42"s (x6!) '03 Jeep Wrangler Rubicon '79 Chev 3/4 Suburban 4x4, 400-400-203 |
I cut my 4x10 brackets to fit 6x9s.
Anthony 07 Tahoe LT 70 Chevelle 450HP 383-TH400 77 GMC Royal Sierra~Resto in progress~ |
Ken, 6x9s are better than 4x10s not only in design, but in availability too.
Professional Grade
6 x 9s will outperform a 4 x 10 anyday, if you've got a good enough 6 x 9 with enough juice running to it, you can get them to perform like a small subwoofer.
How does a guy mount some speakers up front? I don't have any room under that dash for speakers...
#7 | |
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
#8 | |
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
3.5 at the max wont really hold anything bigger than that. You can get some good qaulity 3.5 with tweeters built in and some nice 6x9s you will have a good sounding system .
#10 | |
Dennis |
i put my 6/9's in the doors. they sound great! i didnt have any room behind my seat after i built a massive box back there so that was not an option for me. i also have 3 1/2 2 ways in the dash. i would think if you just made or bought a 6by9 box and threw them behind the seat, you would be ok. you can check out my stereo here
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 Last edited by C-10volvo; 01-24-2004 at 09:31 PM. |
Professional Grade
Well, we'll see about installing some more speakers up in the dash, but I'm still gonna go with the rear amplified 6 x 9s with the small tweeters in them, and a set of door speakers for sure. Not too sure where I am gonna put the head unit in though...
#13 | |
#14 |
Ob-Gyn Kenobi
and also, don't butcher your poor truck just for a couple speakers..the kickpanels work too well to justify cutting..
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. |
#15 |
Professional Grade
My doors have factory mounted speakers in them, and no speakers under the dash
![]() Does anyone make one for our trucks, or will I have to fab some somehow? My stereo is going into the glove box
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 01-24-2004 at 11:35 PM. |
#16 |
Professional Grade
#17 |
I have some 3.5's in the dash, I had to cut holes in the dash(no spot for them in the 73-80), but I have a 81-87 dash pad so the pad was good. Then I have some 6.5's in the bottom front of the doors. If I ever want to get rid of them I just have to replace the carpet piece there to cover the holes.
-90 454ss http://www.imagestation.com/album/?id=4289115843 -04 TRX450R -77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD -82 c-10 SOLD -02 CRF450 SOLD |
#18 |
Professional Grade
When I buy a new dash pad I am gonna buy an AC dash pad, as well as an AC bezel so I can run heater ducting that comes out front. I guess I'll pick one up that is from the 81 - 87 trucks so I have a spot for front speakers.
#19 |
5 day ban, learn to behave.
yeah putting them in the kickpanels sucks. Especially at high speeds, there is a LOT of air forced against the back of the speaker, rendering it useless (ask me how I know!!)
Ive heard a lot of good stuff about the q-logic panels and I'll probably do that eventually.. In the bottom of the door works pretty good. Ive seen 6x9's and 6.5" rounds down there, both sounded good mike |
#20 | |
as for mounting the speakers under the dash, if you use the factory 3.5" speaker brackets, they mount underneath the top of the dash panel, and you never see the speakers. as for the delete panel, they did make those. however, its just a black plastic piece, its not the brushed aluminum. the bottom of your bezel is black plastic anyways, so anything else would look out of place. i have both the factory speaker brackets and a delete plate that i may be interested in parting with for the right price. |
#21 | |
As far as that and water is concerned get some of these ive got a truck with 6x9 blakputs in the doors with a pair of these and i havent had any problems and they jam pretty good for beind down low Link ![]() |
#22 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#23 | |
Professional Grade
#24 |
pull em off, and look for a 7 or 8 digit casting number on them, or a General Motors stamp of some sort. i'd almost bet you wont find anything.
#25 |
Insert Witty Text Here
1FaastC10:
Look at this picture of a Jimmy in a GMC brochure: http://www.tocmp.com/brochures/GMTru...mmy-03_jpg.jpg From here: http://www.tocmp.com/brochures/GMTrucks/1980/index.htm Slonaker Last edited by Slonaker; 01-25-2004 at 04:23 AM. |
