Old 01-24-2004, 02:52 AM   #1
jacquesdean
Question BB Heads < need info
I have 3 numbers
1408045
346236
1409236
What are considered to be the best oval port heads to build,
what are the above casting numbers worth,
Thanks for the input.
Jock,
Powder blasting shop, Alabama
jacquesdean is offline   Reply With Quote
Old 01-24-2004, 03:19 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Best oval port heads are the 049's and the 781's. I am not familiar with the ones that you posted.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 01-24-2004, 06:59 AM   #3
zyggy72
Can't kick the addiction!
Breeh is right, 049's & 781's are the best stock oval port open chamber heads to build for a street or street/strip application. If you find a set of either head you will want to send it to the machine shop to be machine for larger valves, 2.25 intake and 1.90 exhaust. The larger valves combined with some port & polishing will make those heads some of the best cast iron heads you can get. Right now I'm on the porting & polishing stage with the 781's that I have.
The casting numbers you have:
1408045: did not find.
14081045: 78-87 454 open chamber oval ports (generic head, not high preformance)
346236: 75-87 454 open chamber oval port (non-preformance "peanut" port, good for low hp high torque)
1409236: did not find
14092360: 86-88 454 truck open chamber oval port (generic head)
Hope this helps...
zyggy72 is offline   Reply With Quote
Old 01-24-2004, 07:47 AM   #4
Pont
I need another Barley Pop
Pont's Avatar
How about some closed chamber oval ports? Can they be made to run?
Casting number: 3872702
Sorry for high-jacking the thread.......
Rob
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-24-2004, 01:50 PM   #5
JimKshortstep4x4
Talking
According to Morton, the 3872702 heads are 65-66 oval port, closed chamber heads for 396,427 with 98 cc chambers. I think that they are a decent enough head but they are no where close to the aluminum aftermarket heads that are available nowdays.
The seats should be changed to hardened seats and with a little work they will work well. If done right you will spend some big bucks on them, though.
The high performance heads in those years were the rectangular heads.
Here is a link to Morton.
Jim
http://www.mortec.com/bbc.htm
