front drum brakes problem
Anybody have a good way of getting front drums off a truck? My truck had been sitting for a long time, brakes work fine, but want to repack wheel bearings and kind of have a feeling might need new drums now, guessing brake pads catching on groove. Any suggestions would be greatly appreciated.
Thanks |
Designated A-hole!
To get the drums off of my 70 you have to remove the wheel bearing (good thing you were planning on repacking them anyways). First thing to do is get a screwdriver and back off on the adjuster at the bottom of the drum, then pull wheel bearing, then you may need to take a hammer and tap around to free everything up.
Good luck, Krue
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Yep, remove the axle nut.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
There is no slot at bottom to loosen the adjuster on my front brakes, but I will take nut loose, that makes sense.
Thanks for your help! |
Designated A-hole!
Check your drum for a small plate that you can knock out for the slot. I have seen that a few times.
Didn't see any when I was cleaning under there, but will take another look. I really appreciate your help
riveting
Your drum is probably riveted to your hub, so the advice to remove the axle nut and bearing is right on. I think you may be looking for the brake adjuster slot in the wrong spot. Don't look under the drum, it's on the face of the drum at the bottom. If the drums were replaced, they knock-outs may not have been knocked-out (as mentioned above), but if that were the case, your drums would no longer be riveted to the hubs.
good luck, scott
Silence is golden, duct tape is silver. - Scott |
#8 | |
English Chevy Owner
Re: riveting
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
Thanks for your help everyone! Used a punch to knock out the hole, loosened the adjuster, took off the nut, and the drum came off! Never worked on this type of brakes, wouldn't have made the connection of the drum riveted to the hub. Couldn't have done it without you.
Designated A-hole!
Glad to hear everything worked out for ya.
