Drive it like U stole it
door help please!!!!!
okay , I have put new door rubber on and I had to adjust the striker to get the doors even with the body. Now the problem is I have the push on the door when i try to lock it . IF i dont push on it it wont lock . I also put new window fuzzies in about a month ago and my windows are Bit*h to roll down . Help!!!!
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
CCRider
Pretty normal for new rubber...one GA summer will fix that, just takes a little time....probably should have left the strikers alone...it would have panned out. New had trouble with the fuzzies
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
The door seals are hollow, did you cut a notch where the ends join up so air can escape? It usually takes a little while for them to settle in. After I installed mine I had to tell passengers to close the passenger door "with authority", as thats the door thats least used and takes a little longer for the rubber to settle than the driver's side door.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
