01-24-2004, 09:15 PM | #1 |
Those Two Little Fuse Holders On Each Side Of The Truck
WHAT SIZE FUSE....goes in these little white fuse holders????
and by the way what do they do???? every thing works i think thanks the rage |
01-24-2004, 09:16 PM | #2 |
user # 2756
4amp for the amp meter.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-24-2004, 10:06 PM | #3 |
Try spinnin 4 rear tars
Where?!
Are you talking about the ones in the engine compartment?! If you are, then they are 4A and both of them are for the ammeter.
If your not, then I don't have a clue what your talking about...
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
01-26-2004, 07:56 AM | #4 |
Where are they located? My ammeter has never worked. If I find these and replace the fuses, will it start working?
TP |
01-26-2004, 09:23 AM | #5 |
UNDER THE HOOD ONE'S BY THE BATTERY......
THE OTHER IS BY THE VOLTAGE REGULATOR AREA FENDER AND RADIATOR SUPPORT CORNERS |
