Old 01-25-2004, 03:17 AM   #1
70short/step
70short/step's Avatar
3rd brake light
I have been thinking of hooking up my cargo light as a 3rd brake light. Has anyone done this? It should be as simple as splicing into the wire from the brake light switch I would think. It would only be used as a 3rd brake light. What do you think?
70short/step
70short/step is offline   Reply With Quote
Old 01-25-2004, 03:22 AM   #2
rn2fine
rn2fine's Avatar
Great Idea. Can you find a red bulb for it? If so I would think that it would be easy to convert. Just run a wire from the brake switch to the light. It's all inside the cab.
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 01-25-2004, 04:51 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
You can also get a kit from ECE but it's a little spindy.... There is also an led kit on the market for the 3rd brake/cargo light..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-25-2004, 12:46 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A couple years ago I went to Radio Shack and grabbed some small reb lights and drilled some holes in my cargo light assembly. Now (if I ever mount it to a cab) I'll have white light cargo lamp and a third brake light.
Old 01-25-2004, 12:47 PM   #5
Longhorn Man
And in the light...
I have yet to actually use it, so i don't know the brightness of it in day light. I am thinking of re-doing it with LED lamps and put in a few more.
Old 01-25-2004, 07:44 PM   #6
Benrs86
Benrs86's Avatar
i put one in my 69 out of a 94-02 dodge. i put the whole deal in, and it has two cargo lights on the outsides and two brakes in teh middle. i dont need cargo lights so i wired the outside two to be blinkers and then the brake lights. so i have a third brake light that are red lensed and blinkers that are white but light up yellow.
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
