01-25-2004, 02:22 PM | #1 |
Cab Mounts
Does anyone have any experience with the polyurathane cab mount kits? Will it make the ride considerabley harsher? Truck is a GMC 3/4 ton. It already feels like the suspension is welded in unless it has a good sized load in it.
01-25-2004, 03:29 PM | #2 | |
20' Daredevil (Ret)
Re: Cab Mounts
01-25-2004, 03:42 PM | #3 |
user # 2756
I installed prothane poly mounts on my 3/4 GMC, it does not make the ride stiffer but transfers more road vibrations to the cab. But not bad, in my situation the rubber mounts were gone and a PO had cut up tires and stuck the pieces over the old rubber mounts. Needless to say it felt better w/ the poly mounts.
P.S. welcome to the board!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
01-25-2004, 03:52 PM | #4 |
PROJECT 7DEUCE
I installed the poly mount's on my blazer and it does bring up some road noise but should last forever.... Welcome to the board from southern oregon..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-25-2004, 05:02 PM | #5 |
No problems except the existing mounts are old, cracked etc. I'm looking to replace them and was wondereing about advantages of polyurethane vs. rubber.
Thanks for the replys |
01-25-2004, 10:49 PM | #6 |
BlahBlahBlah
i have the poly mounts and dont really notice any extra vibration but mine is a 4x4 and its a lil bumpy anyway.
01-25-2004, 11:07 PM | #7 |
I prefer the rubber mounts. If the first set lasted 30 years you should not have to replace them for another 30 with the rubber and the ride is better.
