prepping engine for start - how would you do it?
hi guys!
sorry to not post in such a long time.... lifes just too busy! i rebuilt my 2bbl rochester carb for my truck.... and i'm ready to put it back on..... how would you go about prepping the engine or the carb before i try to start it? a friend of mine said to just pour gas down the carb to get the engine to fire? is that right? is there any easy way to get the carb filled with gas without running the battery dry while cranking over the engine? give me your suggestions! thanks! ![]()
68 C10 Red Step 350 my first child & main focus 58 3200 Apache LWB Step the upcoming project |
Merciless Butcher
A little gas down the top of the carb is not a bad idea. It works better if you put a little gas in a spray dispenser bottle and spray it down the carb while someone is inside cranking it. Go easy on the gas....You don't want to spray too much and flood it. Oh Yeah...Forgot to mention.....Don't use a styrofoam cup to hold gas unless you can run really fast.
Your Bought And Sold....I Got Your Soul! Last edited by gonebad2; 01-25-2004 at 04:10 PM. |
try to time it before you add gas to the equation, just make sure you have a battery charger on hand
try a boat tank to fill the carb then start the engine, then hook up the actual trucks line |
Good luck starting your project. I live about 15 miles from Huntington, looks like a nice truck. Go Purdue!
#5 | |
you must live in one of the small towns around Huntington.... like Warren, Majenica, Goblesville, Bippus, Bracken, etc.... in fact, i have plans to be back in Huntington Tuesday.... i'm making a special drive there for a funeral ![]() nice to meet ya! ciao! ![]()
If its a new engine you need to prime the oiling system and not by turning it over with the started invest or make a good oil pump primer.
oh - no no, its not a new engine.... it was running about 5 minutes before i took the carberetor off....
i just rebuilt the carb, and now i am going to put it back on the engine... the truck probably sat for three weeks without the carb on it... but i kept the intake covered..... there is probably still gas in the fuel line, but i didnt know if i would need anything else to get her going.... sounds like i'll probably try the spray bottle if needed, otherwise, i may just crank her over a few times.... ![]()
Sorry to hear about the funeral. Live near North Manchester. Small world
Professional Grade
When I pulled mine off, I just cranked and pumped till she coughed, then floored it and cranked some more, fired up real quick
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
the bowl on the carb. will fill in about two revelutions of the engine....no big deal.....
if the battery's that low .....change it.... ![]() |
With dry carb installed, pour about a 1/4 cup of gas down the top of the carb, close the choke and crank it. If tuned well, it will start quickly---couple of cranks. Do not look down the carb to check as it can sometimes flash back due to the rich mix---not sure how you would look bald!!!hehehehe
Not a big deal-----just make sure the carb has it's fuel line on nice and tight with no leaks this time---hehehehe or it's back to fine69's for you!! ![]() |
I wouldnt mess with pouring gas in the carb, like the others said just start pumping the gas peddle and it should start after a few tries.
I take it your fixing this thing outside? |
#13 | |
ok - i'll start her dry and see what happens.... ![]()
#14 |
Ugh, Thats no fun! Your welcome to my shop if you find yourself 100 miles south of KC :p
#15 | |
![]() jewels.
#16 |
My other Love
Im assuming that you are going to put a new fuel filter in too?
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#17 |
67-72 truck surgeon
one thing you might try is pouring some gas through the vent tubes to fill the float bowls.
1969 Chevy C10 1993 Toyota Camry LE 1999 Ford F250 Super Duty 4x4 diesel 2008 Dodge Charger Super Bee 1953 International R182 |
#18 | |
oh crap! thanks! i almost forgot! yes, that was my plan, and thank you for reminding me! i was also going to look into replacing the fuel line that i have because the one i have is pretty rusty looking and the nut on the end is very stripped and worn down! hmmm - another trip to the autoparts store! ![]()
#19 |
Catchy title goes here..
![]() Join Date: Mar 2002
#20 | |
Hahaha melted styrofoam all over my hand, no gas in the tank... Fount a couple of those old glass coke bottles in the ditch, managed to pop the bottom out of one with a crescent wrench and use it like a funnel. |
#21 | |
LMAO!!!! ROTF!!!! thanks liz! i needed a good laugh! ![]()
#22 |
its all about the +6 inches
Good one Liz!!!! (I was thinking the same thing though)
Jewels, just crank it over. The bowl on that dinkey carb hold less than a mouth full. Crank it over 2 or 3 revolutions, then tap the gas pedal a few times, and crank it again. It'll start. it's a good running engine...I have faith. If it don't start, then have it towed to Mike's and we'll stay up cussing at it calling it the worst driving POS ever driven. ![]() |
#23 |
I ALWAYS pour gas down the carb in this situation. The running engine can fill the carb bowl much faster than cranking it with the battery.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
