Old 01-25-2004, 05:18 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Stepside Tailgate Options
I want to lose the chains, tail lights and latches. I am wondering what some of you have done to modify your stepside boxes to clean them up but still use them. I have already considered just welding it shut but nixed that idea. Thanks
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-25-2004, 05:33 PM   #2
67cst
i love summertime
67cst's Avatar
i know what you mean, on the 67 i picked up some of those bullet style lights, they are about 2 inches in diameter and mounted them pretty low but not low enough that i cant fit a back bumper on, also lost the chains too, im not sure how im going to latch it so right now ive got rubber hose jammed in where the chain would hook though, i need to figure that out though before the final stages of body work and paint.
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 01-25-2004, 06:03 PM   #3
stepside454
stepside454's Avatar
check out www.wow-products.com
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 01-25-2004, 06:06 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A quickei that I have seen is to put a bolt with a wing nut through the hole where the hook would go to latch it in the up position.
Old 01-26-2004, 03:48 PM   #5
nate68
no tailgate for me.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 01-26-2004, 03:58 PM   #6
Jwill41
Jwill41's Avatar
I have been thinking about using a black net tailgate
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 01-26-2004, 04:07 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Seat Belt's
I have seen people that use the seat belt snaps and buckel's. You could maybe use some kind of magnet that had a safety hook to insure it didn't open going down the road.
Maybe a electric acutuator hidden in the tailgate that pushes the latches into the side of the bed when you want to close it. I have also seen the door latches that you use on screen doors to hold them shut.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
