01-25-2004, 06:22 PM | #1 |
senior member
Would these wheels fit?
I have a 69 would they fit?
http://www.billetspecialties.com/ite...pid=628&rdir=1
69 GMC bagged |
01-26-2004, 10:24 PM | #2 |
Probably not, the center hole is too small to fit the center guide on our drums.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
01-27-2004, 01:23 AM | #3 |
Struggling Artist
have you converted over to disc in front? if so they will fit the front but you will have to have the rear axles machined down to fit the wheel center bore.
69 1/2 ton lwb lowrider 90 C-1500 2wd 08 2500 HD 4WD 94 Grand Cherokee 49 Cadillac sedan |
01-27-2004, 03:05 AM | #4 |
senior member
**** that **** im gonna put them on anyways
69 GMC bagged |
01-27-2004, 10:04 AM | #5 |
need to know bolt pattern, center hole size, offset, made for disc or drum brake.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-27-2004, 11:38 AM | #6 |
Tells you right in the description that it fits 98 - 03 GM 6 lug. You'll have to work to make them fit PROPERLY. Scott
Silence is golden, duct tape is silver. - Scott |
01-27-2004, 11:47 PM | #7 |
Bad69,
Do you replace the tie rod ends when you convert to front disc? The problem that I had with the newer style wheels was that once I changed the center bore size, thay hit the tie rod ends, and that was with standard size wheels, not the wider ones. I do not have the front disc conversions though.
01-28-2004, 01:35 AM | #8 |
Struggling Artist
70 longbed; if you go with 17" or larger wheels it wont matter, they will clear them, but no the tie rods are the same and wont clear 16" or smaller wheels.
01-28-2004, 01:40 AM | #9 |
Struggling Artist
when I converted over I changed everything, drop spindles, tie rods,ball joints,and changed to 6 lug disc brakes,I did install 71-72 tie rods(sorry forgot).i think the tie rods are the same though.
Mitch
01-28-2004, 10:43 PM | #10 |
I see where the larger wheel size would eleviate the tie rod end problem, but I only had a standard size tire, P245-65 16 mounted??? and the tire itself rubbed when I turned the wheel to far in either direction.
