Radiator and Oil Pump Replacement
New to Posting.
I have a 94 K1500 Burb with 180k just purchased with hiway miles back and forth from NC to FL. Truck still has loads of power but the oil gauge seems to float under 40 psi at idle. 1) should I even mess with changing the oil pump with this many miles since I plan on swapping the motor when it finally does go or would it be wise to be preventative (or does this just indicate that it is finally going) and 2) the top radiator hose was removed by Sears ![]() ![]() |
40 pis is fine now if it gets down to 10 start to worry.
LED King
The oil pressure is fine. Oil pumps (almost) never fail. They will last 300,000 miles or more.
Those radiators can be fragile. There are some all aluminum radiators that you can replace them with. Check Jegs and Summit.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
My 89 GMC K-1500 does the same thing on oil pressure and it has 186,000 miles on it. I was going to have a new oil pump installed and my mechanic talked me out of it. He said my motor was just getting broke in. I'm planning to run it till it quits and then buy a new crate motor.
The plastic radiator went to leaking shortly after I bought the truck, and the best deal I found was on Ebay. There is a shop in Oklahoma that I dealt with. I could have bought a direct replacement, but opted for the all brass radiator instead. Haven't regretted it. Bob |
