71 GMC 4X4 Short Bed For Sale
I never thought this day would come, but I'm putting O'Reb up for sale to the board, and ebay if it doesn't sell here. I am going to go into GREAT detail describing the good, the bad, and the ugly about this truck, so PLEASE READ EVERYTHING, as it will describe everything I can tell you about it. If you need additional pictues let me know, I do not want to hide anything, and want the buyer to be as pleased as I have been with the truck. The truck and all extras are sold as a package deal, do not want to sell seperate. Please note all the extras included with the deal, as I have accumulated a lot of extra parts to finish or supplement the restoration of this truck. Asking price is $2900.
The Truck 1971 GMC 4X4 Short Bed. The frame # matches the vin # matches the # (wrong Super Cheyanne glove box door and data sticker) on clear title in my name. 350ci/th-350/np-205. This truck was originally a short fleet side , but I liked the short step better. I include many options that will allow you to turn this truck in to a Sierra Grande if you so decide. The 3/4 ton springs have been recurved and give about 4-5" of lift without blocks. 16.5" aluminum rims with 33" all terrains. PS, PB. Many, many extras are included (read everything). This truck runs very strong and is built to perform in the toughest conditions. Asking price is $2900 The Motor Done prior to my purchase, has less than 2000 miles on complete rebuild. I have no documentation but believe everything to be true and correct that this motor has been done right and everything stated is true. I have previous owners info to contact. The motor has not been touched by me, and still looks and runs like a high performance machine. (see pictures). It has definately been taken apart, rebuilt, and painted prior to installation. It has a nice lope to the idle from the hotter cam. 350 block, 4 bolt main, bored 30 over 10:1 compression flat top pistons and new rods Lunati 268* cam 87-95 300hp heads with hardened seats and valves Weiland dual plane aluminum intake Holly 750 carb with manual choke Hooker headers Electronic ignition distributor MSD Blaster 2 external coil MSD 6A ignition New fuel pump New starter New water pump New 5 blade fan Boiled out rodded 4 core radiator The Drive Line Done prior to my purchase (except NP-205), has less than 2000 miles on complete rebuild. Rebuilt TH-350 automatic tranny with shift kit Rebuilt NP-205 transfercase (I had done in 3/03) New adaptor for TH-350/NP-205 (purchased from GM 3/03) New custom built racing drive shafts (super heavy duty) Used Dana 44 (3/4 ton) front axel with spicer lock outs (unknown ratio) Used 14 bolt (3/4 ton) real axel with posi (unknown ratio) <note> axels came from a 70's model Chevy 3/4 ton suspension with recurved springs to give no block 4" lift Front springs have new poly bushings Front suspension is 3/4 ton and is new and tight The Frame Original 1/2 ton short wheel base frame in very nice shape. There is no repair to steering sector section. The truck drives straight and clean with no dog tracking. The frames original engine cradle was cut out by a previous owner to allow a deep sump oil pan clearance. A piece of stock was welded in the cut out area below the motor mounts. I have a replacement 1/2 ton engine cradle to replace the fabricated one. The motor mounts were fabricated and welded to the old cradle, and the replacement will allow for original small block motor mounts to be used. The rear fleet side bumper has been welded to the frame using home made bumper brackets. The Sheet Metal Front bumper is of 71-72 Chevy design, no marker lights Front grille is original and only needs to be re-chromed Front top grille is original and has 2 small dents and needs re-chromed Both eyebrow chrome pieces need re-chromed Core support is original and shows no visible rust rot Both inner fender are original and show no visible rust rot Both outer fender are original and right side shows minimal rust rot The hood (as shown in pics not included) the hood from front clip pics will be included which is in good shape. Original non-A/C cab need replaced or extensive rust repair (the cab corners, rockers, floor, frame supports are bad, rest is okay) Driver door is original and has lower end rust Passenger door is a 72, and is in good shape Both door window regulators work very good The short step bed is very nice. Already aluminum oxide blasted and etching primered. Has diamond plate as bed floor over original wood and strips Both rear fenders are in acceptable shape Bed steps are in good shape (not installed, can get pics) Bed front panel is bent and dented and will need replaced Tailgate is in good shape with bondo used on one dent, one rust pin hole. Has both tail-light and reverse brackets, only has taillight assemblies. The Glass Windshield is original, no pecks or cracks but is cloudy at edges Both door glass is good Rear slider works and locks, passenger side is pexiglass What I Feel Is Still Wrong The engine cradle as stated above (have part to fix) Front brake lines need lengthened Emergency brake lines work, but are stretched to the limit Speedo cable inop Needs tranny kick-down cable Gas gadge inop Wiring is a mess, but works Dash is cut for radio reciever I'm including Ignition is based on turn the key, then push a button What Is All Included With Purchase NOS ashtray in black New in box from LMC front fender emblems (1500 Sierra Grande) New in box complete aftermarket wiring harness from Haywire New in box cab mount rubber and bolt set from Chevyduty New in box aftermarket passenger fender 9 out of 10 "Four Wheel Drive" fender emblems 9 out of 10 "sierra Grande" fleet side bed emblems Perfect original "Sierra Grande" glove box door emblem 2 extra fiberoptic column indicator wires Extra set of used headlight bezels 3 point mirror parts and pieces Extra set of (4) 16.5" steel aftermarket rims and bad 33" tires Single bar roll/light bar for fleet bed with 4 KC lights and 3 other brand Pioneer Super Tuner III DIN type removable face AM/FM/Cassettte, dash cut for radio (radio installed, no speakers) Small vehicle sized fire extinguisher used but working heater fan Blue headliner painted black with painted chrome trim thats broken Blue Cheyanne super door panels with can of black vinal paint NP-205 to frame torque brackets and and new bushings Restored cup holder console vinyl pained black 2 sets of Blazer buckets needing foam and upholstry (no brackets) 1971 A/C cab Alum. Oxide blasted and etching primered, typical rust (see picture) GMC front cap, clean (see picture) Asking price is $2900. This is what O'Reb looked like at purchase. Last edited by dtlilly; 01-26-2004 at 03:03 PM. |
71 4X4
This is a picyure of the motor after a light cleaning. It still has evidence of muddy water that splashed up and hasn't been cleaned. This is not a quick repaint, all I did was wipe things down.
Nice Shorty 4X4
This is a picture of what the truck looks like today 25Jan04.
dang i wish i was closer nice truck
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
Rare Original Shorty 4X4
Here is a picture of the truck from passenger rear.
Short 4X4
This is a picture taken today of the driver side rocker rust.
Original Short Fleet 4X4
Here is a picture of the driver side rust in the floor. Fiberglass was used to try and repair the holes, as well as sheet metal. As I said in description, the cab (in my opinion needs replaced), but I have a clean A/C cab included.
4X4 Short Fleet Turned Into A Short Step
Here is a picture of the bed that has been aluminum oxide blasted then etching primered. The bed has diamond plate welded on top of the original wood and metal spacers. No rust or dents on the bed sides.
71 GMC Shoet Bed 4X4
No picture of a GMC is complete without showing the front grille. Notice the new bushings in the 3/4 ton recurved springs. Front bumper is 71-72 Chevy, and buyer elects to keep, or I will remove.
There is more rust there than in picture, look close and you can see it. Last edited by dtlilly; 01-26-2004 at 01:48 AM. |
GMC 4X4
Here is a picture of the passenger side rocker area rust.
Extra Wheels For The 4X4
The rims and tires I got when I bought the truck are also included. The cool looking rims and tires on the truck were bought from a board member in late 2003 and come with the purchase.
71 4X4 GMC
This is a picture of the short step side bed and the 71 A/C cab I bought from board member jacquesdean (Jock), who owns a powder blasting shop in Alabama. The bed is on the truck and the cab is included with the purchase. Both have been aluminum oxide blasted to bare metal, then etching primer used to prepare for whatever paint you decide.
#13 |
Buy This Rare Short Bed 4X4
This is a picture of the included front clip I am getting from Ozark Hippy. The Chevy hood on the truck is not included, but the hood on this front clip will go with the whole deal. More good fenders here (passenger side has messed up marker light in it).
#14 |
Short Bed 4X4
150 lookers and no offers. I lowered the price to $2900.
#15 |
WELL worth the money IMO. Somebody is gonna get a steal on that. I wish it was me, I've been sitting here trying to figure out how I can afford it, but haven't come up with anything yet. Can you hold it till I get my taxes done?
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
#16 |
Trucks For Sale
I'll be sending you a PM. I hate to be doing this, but my C-30 is also going to be sold soon. I may have to move to Milwaukee Wisconsin to take care of my mother and I'll have no place to keep them up there.
#17 |
ready for reassembly
hope you sell it....but it sucks that you have to. good luck, looks like it's well worth the money you're asking.
Jason
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
#18 |
To The Top
Bringing ttt for the evening bunch. I lower the price to $2900 for a quick sale.
#19 |
"Ochre Ogre"
If this was April, I'd be bringing my trailer to the truck show in Pigeon Forge. A little trip west on the way home is all it would take.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
#20 |
Too far away for me....
I should thing with everything you have for it that it would sell fast............
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#21 |
ttt
#22 | |
#23 |
I'm interested, how about detail pics of the extra cab. What kind of rust did it have? Do you still have the fleetside bed?
#24 |
Barrza, I can get pics of the extra cab Thursday AM. It's a manual tranny A/C cab. The cab supports are real good as are the window frames, kick panel areas and fire wall area that usually rusts. The only rust is rockers, minimal floor next to rockers, and might need corners. It's a low hump cab.
Where in N. Alabama are you? I was down to Sneed then across Wheeler Dam on the way to Killen, then 72 back to Memphis. |
#25 |
Young Gun wth Fast Inline
ttt for ya. A rough thing your doing but a good one.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
