Old 01-26-2004, 05:38 AM   #1
GMC_Aaron
Rear Axle I.D. Confusion
I was trying to pull the axle codes the other day, because I need to change the cover gasket. I have read about casting locations and couldn't find the code that is supposed to be on the passenger side of the rear axle. What gives? I was able to pull a couple of numbers off the axle. One was on the carrier itself, passenger side, facing towards the front and it read GM 30. The other number I found was on the driver's side axle tube, facing towards the front. Will these numbers tell me anything? I'm thinking that this rear axle isn't the original.
Aaron
Ventura, Ca.
1972 GMC Super Custom SB350/TH400
GMC_Aaron is offline   Reply With Quote
Old 01-26-2004, 09:38 AM   #2
Blue Beard
Blue Beard's Avatar
I've had the same issue........can't find any numbers.....
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-26-2004, 11:30 AM   #3
GMC_Aaron
The number I found on the left side as described above is: 1405525.
Aaron
Ventura, Ca.
Old 01-26-2004, 03:36 PM   #4
69k5
95 percent sure thats the same number thats on my 12 bolt. if its not a 3rd member (gears ubolt and drop out the front) then count the bolts . its either 10 12 or 14.
69k5
69k5 is offline   Reply With Quote
Old 01-26-2004, 05:41 PM   #5
GMC_Aaron
Mine is a 10 bolt. I'm not seasoned on rear ends yet, but I have a posi that I would like to throw in if possible. I just wanted to figure out what rear end I had before I tear into it. I have searched all over the web with these 2 casting numbers and have had no luck.
Aaron
Ventura, Ca.
