01-26-2004, 08:24 AM | #1 |
Ever wonder the difference between BT's 6" Flip vs DJM's 5" Flip?
I've always wondered why the BellTech's are rated for 6", while the DJM is only 5"...same parts, looks like..hmm..anyone know?
BellTech's: DJM's: Hmmmmmm.... Last edited by TIMSPEED; 01-26-2004 at 08:28 AM. |
01-26-2004, 12:52 PM | #2 |
Happy to be here
Look at the bump stops on the BellTech kit they are taller. Yeah that's what it is, the bumpstops are taller...
01-26-2004, 02:36 PM | #3 |
those are some skimpy looking bell tech notches............only 6 bolts..............
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-26-2004, 06:45 PM | #4 |
Western Chassis stuff looks way beefier than either of those.
01-26-2004, 06:51 PM | #5 |
Insert Witty Text Here
Could it be related to the variaton in the amount of drop you get based on the thickness of the spring pack? My understanding is that you get more drop if you have more leaves. Maybe one vendor states the maximum you can get and the other states the minimum.
Slonaker |
01-26-2004, 08:41 PM | #6 | |
Are you talking about the C-Notch portion of the Flip Kit? If so, I'm not debating that here, I'm debating the difference in the actual FLIP KIT and what makes it 5" or 6"... |
01-26-2004, 08:47 PM | #7 |
DJM = $90
WC = $80 Hmmmmmm....So I will have to start endorsing the WC Flip Kit...since it's $10 cheaper! |
01-26-2004, 09:01 PM | #8 |
Is wester chassis the same as chassis tech. That what I get up north here at a shop and they claim it's the best..and for all I know it is. I don't know about if I got the full six inches out of my drop though.
Dennis |
01-26-2004, 09:09 PM | #9 |
pre drop...
Dennis |
01-26-2004, 09:10 PM | #10 |
post drop... 4/6
Dennis |
01-26-2004, 09:53 PM | #11 |
the only way belltech could make there flip lower than any other flip would be in the design of the saddles if the saddle were designed taller, as in the "U" shaped portion moved up further that would drop it more. it would be like adding a 1 inch drop block on a flipped axle
01-26-2004, 09:54 PM | #12 | |
01-26-2004, 10:24 PM | #13 |
The difference in drop is going to be the difference in the thickness of the spring pack. They advertise them as different rates based on 'typical' installations & don't guarantee the 'exact' amount of drop because of variances in different vehicles.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-26-2004 at 10:27 PM. |
01-26-2004, 10:33 PM | #14 | |
Under construction!
No, the two companies are not the same. Chassis Tech (AIM Industries, Truckin' Suspension, etc.) has a poor quality and service reputation. Stay far away from their components.
2001 Silverado bagged on 22's. *Sold* |
01-27-2004, 01:12 AM | #15 |
i have seen shAIM flip kits, and owned their shackles, hangers, and drop spindles. i have also owned a Western Chassis setup including flip kit, c-notch, shackles, and spindles. the shAIM parts were visibly cheaper (casting flash on the spindles, welds werent as good of quality) than the WC stuff. there is NO way that these two products are "the same".
01-27-2004, 01:21 AM | #16 | |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-27-2004, 03:24 AM | #17 |
i fixed it douchebag, are ya happy?
hey Josh, is there any way we can get a spellcheck feature added to the board? |
01-27-2004, 11:44 AM | #18 | |
Slonaker |
01-27-2004, 02:19 PM | #19 |
Mudslides 'r my specialty
$80 or $90?
I think PSC has them for $60...
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
01-27-2004, 03:38 PM | #20 |
Under construction!
$10 difference, big deal.
I've had both WC and DJM flip kits for my previous truck. I was more impressed w/ DJM's product. The finished product looked much better---Powdercoat is durable, the holes were drilled straight, and the edges were nicely finished. The WC kit was on the "rough" side. I observed this in both flip kits I purchased from them.
