Old 01-26-2004, 10:33 PM   #1
70Chevy4x4Nut
What would you use between Leaf Springs?
70 rear spring Leafs.
I took apart the leaf springs to paint. It had a small piece (6" long)of plastic or teflon on top of the overload spring. What have you guys used between leafs?
1. Nothing?
2. Put them back like they were?
2. Teflon between all leafs? If so, where could I get them? How much of the leaf do you layer?
3. Or use Grease?
4. Anything else I haven't mentioned?
70Chevy4x4Nut is offline   Reply With Quote
Old 01-26-2004, 10:51 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I just cleaned mine and put them back together when I add an add-a-leaf, left the piece of plastic off.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-26-2004, 11:38 PM   #3
402Bowtie
402Bowtie's Avatar
I think LMC sells the plastic pieces for 5-7 dollars.
402Bowtie is offline   Reply With Quote
Old 01-27-2004, 02:12 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
I put 'air' between mine on my old CJ. Only squeaking I had was from my urathane bushings
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-27-2004, 02:20 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
What kind domestic or import
jamis is offline   Reply With Quote
Old 01-28-2004, 03:24 AM   #6
SWEET7T
SWEET7T's Avatar
It was domestic... I bottled some air in the airplane while I was flying from Arkansas to Vegas. I was happy with my results; springs were quiet, and I swear that the quality of air has an effect on the amount of travel the spring will produce!
SWEET7T
Old 01-28-2004, 08:52 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All of the street rod places sell the plastic by the roll. You just cut to length. I line all of my leaves personally. The more the better.
You'll likely pay more, but your local spring shop will have it too. Look in the phone book under "springs".
Old 01-28-2004, 09:22 AM   #8
70Chevy4x4Nut
I tried LMC catalog and did not see them in there. I will call them and call locally. Thanks for the hints.
Old 01-28-2004, 09:45 AM   #9
Blue Beard
Blue Beard's Avatar
Mile High?
Bottled it while flying...........
1) too much booze
2) Mile high Club
3) Better price on the bottled stuff
4) what were you smoking
That thing have a lift off...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-28-2004, 12:09 PM   #10
SWEET7T
SWEET7T's Avatar
It was the price...
That was about the 'best' air I could get for free. He he he I kinda stole it from the plane in a big jar I had in my bag
SWEET7T
Old 01-29-2004, 06:33 PM   #11
70Chevy4x4Nut
Found a place that would punch 1/2" holes in the ends of each leaf and snap a 2-1/2" round teflon insert in the ends. This is how many new springs are done. very reasonable on price too. He said he would heat up the spot and punch the hole out. This shop is in the business of re-arching leafs and working on suspensions. What are your thoughts about doing this? Any pros and cons? Am thinking I may go tomorrow so any advice tonight would be appreciated.
Old 01-29-2004, 07:02 PM   #12
Tx Firefighter
Teflon buttons are great. I have a set of real expensive Posies brand springs on my 54 that are like that. Very smooth and quiet.
Old 01-31-2004, 12:00 AM   #13
70Chevy4x4Nut
Well I went to the spring shop and not only had the teflon pads installed but had them re-arch the springs. They were both sagged about 3/4". One was 1/4" different than the other. Not too bad, but they did all of it for $60.00, turnkey. I couldn't pass it up. I came home and installed them with poly bushings. I'm glad I had the pads installed. Can't wait to see how it feels. Will be awhile.
