Old 01-26-2004, 11:27 PM   #1
desertchevy
no headlights
Hey Guys,
I have no headlights. Checked all my fuses, replaced the switch. I have power to my dimmer and switch but nothing to the headlights. Thought that both bulbs might be bad (doubt it)and I had already ordered the H4 conversion from Shawn at **************** so I put those in. Still nothin and I would really like to see those work. I have my brake lights,running lights, blinkers, hazards everything but no headlights. Where is the headlight relay located? Thanks for your help. I'm starting to get pissed and I'm sure I will be more so when I find that it is something simple that I overlooked.
2006 Dodge Quad Cab 4X4
2001 Chevy Impala
2006 Corvette
2009 Fusion
1964 Toyota Landcruiser FJ45 Wagon
desertchevy is offline   Reply With Quote
Old 01-26-2004, 11:36 PM   #2
Sounds like your headlight switch or dimmer switch to me. Probably the connectors to the headlights went bad, or the dimmer switch from where it sets went bad. Check to see if you have any type of voltage in and out of the dimmer and at your the sockets.
I am pretty sure these trucks don't have a relay setup from the factor for headlights. That is why they tend to be dull because they don't draw full a full 12 volts.
I don't have my wiring diagrams handy with me in the house, but the switch or dimmer switch is the only thing I'v ever seen or heard that gives you indications
Old 01-26-2004, 11:38 PM   #3
dmurphy68
I had the same problem change you dimmer switch and that should fix your problem. If that does not work star looking for broken grounds. I had power to my dimmer switch too but replaced it and everything worked again.
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 01-26-2004, 11:53 PM   #4
desertchevy
You know I almost bought a dimmer switch while I was at NAPA. They worked one day and not the next. Kinda weird. Anyway thanks for the input , I will get a new dimmer tomorrow.
2001 Chevy Impala
2006 Corvette
2009 Fusion
Old 01-27-2004, 12:52 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Check the ground on the core support passenger side.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-27-2004, 01:22 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you were to kick your dimmer switch, or just flick it from low to high, I'll bet they will at least flicker.
Don't forget to inspect the harness plug and the dielectric grease when you dig into it.
