zz502 parts for sale
These are pulloffs from my ZZ...if they don't go here then I will put them on Ebay...
Black Aluminum valve covers $60 Street Avenger 870 Carb/elec Choke Vac sec. $250 ZZ502 Roller cam $75 GM Dual plane intake (Edelbrock performer oval port) $90 All of this has less than 500 miles on it.... I also have the hyd lifters as well if someone is interested...
FocuzTech Performance Evergreen Protective Coatings Gatorhyde...the best kept secret in spray in bed lining & protection |
Could you e-mail a pic of the valve covers? Email is kenw777392@iwon.com Thanks JIM
68 short fleet with 71 front clip 2wd jaguar blue ![]() 99 chevy ext cab shrtbed z71 loaded ![]() 99 chevy swb fleetside(daily driver) ![]() Sparks, Nevada |
Here is a pic of the valve covers installed...
Thanks for the quick reply. How much would you want shipped to 89434. Thanks jim
I guess I should ask if those will work on the older heads first. JIM
those should work on older heads. unless they changed them, all you have to do is grind or machine of the o-ring lip. they should be fine with that modification.
Anthony |
#7 | |
![]() Join Date: Feb 2003
intake
Will that intake bolt onto a 454 ? Thanks.........Zoomy
Well put me in line on the covers but could you do me a favor?
I am trying to see if these will fit on my 454 and clear the A/C bracket. Could you set them on a flat surface and measure how tall they are? and how far from the edge the angles part goes vertical? Hope that make sense. ____ ........\ <------ this angle area. ![]() .........| --------- Thanks.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#10 | |
Re: zz502 parts for sale
**************** has dibs on everything else....
sent you a pm
Everything is sold!!!!! Thanks guys!!!!!
#13 |
covers
Hey Grim Reaper if you are talking about a truck ( 67-72 ), they will clear. See photo:
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
