01-27-2004, 02:43 PM | #1 |
1bbl rochester 6 cyl. carb FS- rebuilt
$50.00 plus shipping. Please respond here.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
01-27-2004, 02:52 PM | #2 |
What year and size engine did it come off?
11 Surbaban 70 C 10 still in progress |
01-27-2004, 03:12 PM | #3 |
Not sure. I got this with a group of parts, and there was no box. 1 & 3/4 bore, 2 & 5/8 air cleaner base, manuel choke. Looks like it takes a 5/16 fuel line, and a 3/16 metal vacuum line to the dist. I don't see any numbers on it.
01-28-2004, 12:04 AM | #4 |
ttt
01-28-2004, 12:39 AM | #5 |
carb
more pics..other side, top..are there any #'s on it? I need one for my 70 -250 want to make sure it will work.
Thanks. |
01-28-2004, 12:48 PM | #6 |
1
01-28-2004, 12:48 PM | #7 |
2
01-28-2004, 12:53 PM | #8 |
I can't find any numbers, but I would bet that this carb is for 67-72 230s and 250s. I think the 292s had a bigger one. It's been a while, but I have worked on them before, and if my memory is correct, this is it. I got this with a pile of 67-72 chevy truck parts.
01-28-2004, 12:54 PM | #9 |
3
01-28-2004, 03:32 PM | #10 |
Out of the carpool lane.
This is a Rochester B carb. It was used on 67's. 68's on up had the Rochester MV style carb which were more square-ish in shape.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
01-28-2004, 03:57 PM | #11 |
Thanks for the info, Brad. I knew it was just a matter of time before someone figured it out. I showed it to a parts dealer a few minutes ago, and he said the same, pre '68. I would think that it would still work on later models, but not sure.
01-28-2004, 05:10 PM | #12 |
How's a guy suppose to know if it'll work on diff year 6's.
01-29-2004, 01:32 PM | #13 |
This carb uses a rod linkage so you couldn't use it with the cable style linkage unless you swapped it out.
01-29-2004, 02:33 PM | #14 |
Young Gun wth Fast Inline
looks like a 292 card, they had the bigger bore. i coould be wrong though. the carbs are enterchangable.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
01-29-2004, 04:03 PM | #15 |
There was only one size for these carbs. It'll fit a 292, 250, or 230 but it all depends on the linkage you've got.
