Old 01-27-2004, 04:25 PM   #1
laxplaya37
Disc Brakes on 68'
My dad has a 1968 C10 with drum brakes that hes going to sell to me.. He also has two scrappers 71' and 72', I was wandering if possible what is needed to take disc brakes off 71' and put on 68'..
Thx
laxplaya37 is offline   Reply With Quote
Old 01-27-2004, 06:38 PM   #2
gr8scott51
gr8scott51's Avatar
Swap the whole front crossmember.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-27-2004, 07:26 PM   #3
krue
Designated A-hole!
krue's Avatar
What he said, plus booster, master cylinder and proportioning valve (funny shaped doohickey next to master cylinder). May also want to swap rearend to get 5 lugs all the way around. Have fun!
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-27-2004, 07:56 PM   #4
laxplaya37
thx guys, I'm not very mechanically inclined so idk all that stuff but I'll tell my dad, he manages a Transmission Shop and if he has any more questions about it ill be back
Thx
Old 01-27-2004, 08:08 PM   #5
zenish
wouldn't the crossmember be the same between a 68 and 71?
zenish is offline   Reply With Quote
Old 01-27-2004, 09:41 PM   #6
gr8scott51
gr8scott51's Avatar
Just fewer parts to take apart.
Old 01-27-2004, 09:44 PM   #7
laxplaya37
The configuration on the 68' and 71' of the spindel is different on the trucks will it still work?
Old 01-28-2004, 01:00 AM   #8
krue
Designated A-hole!
krue's Avatar
Yeah, just swap crossmembers, that way your brake lines are all running on the right side of the crossmember.
www.daveramsey.com
Old 01-28-2004, 08:51 PM   #9
Low69CST
If you think you'll need to replace the ball joints in the disc brake crossmember, you might as well keep your current stuff and just put 71 ball joints in your current A-arms, then bend lines to go over to the correct side for the rubber brake lines.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
