01-27-2004, 05:33 PM | #1 |
Kickdown problem
I have a 350 with a 400 turbo. When I floor it it kicks down to passing gear but it wont come out of passing gear unless I drop gerars from D to L2 and back then it works. Any ideas what could be causing this?
Thanks Last edited by skokie; 01-27-2004 at 07:52 PM. |
01-27-2004, 09:00 PM | #2 |
its all about the +6 inches
A sticking vacume modulator, or a vacume leak feeding that line.
01-27-2004, 09:05 PM | #3 |
Vacumn Modulator? How hard is that to change out?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-27-2004, 09:38 PM | #4 |
On pass side of trans-will have a vacumn line going to it-only 1 bolt to remove-pull out the old push in the new- install bolt and vacumn line-done.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
01-27-2004, 10:56 PM | #5 |
Ok sounds easy enuff. Should I expect a flood of tranny fluid?
01-27-2004, 11:45 PM | #6 |
no-mostly above fluid line.
01-28-2004, 01:11 AM | #7 |
May do this tonight. I got the modulator.
Thanks again.
01-28-2004, 02:28 AM | #8 |
Ok Modulator changed out did notice that the old hose had a crack in it. I have replaced that as well however problem still here. What else should I be checking?
01-28-2004, 03:46 AM | #9 |
My other Love
um the switch on your gas pedal could be sticking? or is the switch on your carb?
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
01-28-2004, 01:42 PM | #10 |
Does it change into high with regular driving?
01-28-2004, 03:37 PM | #11 |
Switch is on the carb and I checked it. It does not appear to be sticking. It does change into high with regular driving but sometimes when you first start out you can put it in drive and it wont change to 2nd unless you change it manually from D to L2 and back again. After that as long as you dont put it in park it works fine.
01-28-2004, 04:05 PM | #12 |
Can't kick the addiction!
I wonder if it could be a problem with the fluid flow in tranny that is causing the problem. When was the last time the fluid and filter were changed?
01-28-2004, 04:25 PM | #13 |
Fluid was changed out two weeks ago along with a new filter.
01-28-2004, 04:56 PM | #14 |
The Blazer King
Don't mean to hijack but I wonder if that vacuum modulator would keep the tranny from downshifting into first? Mine never drops down by it's self when I come to a stop. Anyone know?
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
01-28-2004, 05:34 PM | #15 |
i have been having aproblem similar to 2wdblazers on my '85...it seems like it doesnt want to downshift when i slow down...vaccuum modulator?
-Nick
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
01-28-2004, 06:05 PM | #16 |
Next thing to check is the governor-it could be worn or sticking-it is the round bowl like thing on pass side of trans. The cover can be removed by taking the spring clip off. Some fluid will run out-not much. Pull ass. out and check to see it it is sticking or replace with known good one.
01-28-2004, 06:11 PM | #17 |
Is it on the front of the tranny or the back on the passenger side? Where is it in relation to the vac modulator?
01-28-2004, 06:41 PM | #18 |
here it is
01-28-2004, 06:47 PM | #19 |
In the middle. Got it. Rookier question here but what should I do to test it?
01-28-2004, 06:47 PM | #20 |
Sorry wrong picture--here is the 400
01-28-2004, 06:53 PM | #21 |
The weights should move in and out easy-as the weights spin then move outward causing the shaft to cover or uncover holes to make trans shift. I am not a trans expert either so I do not refund any money on advice. LOL
01-28-2004, 08:03 PM | #22 |
Cause the Chicks DIG IT!!
that still sounds like straight up vaccum problems to me. I'm no tranny expert by any means either though. You've changed the modulator and changed the rubber line but have you changed the whole line to a rubber piece? The line itself should be metal most of the way except for where it plugs in at the tranny and at the manifold. I'd check to make sure you got a good connection at the right spot on the manifold too. I see some people that run all rubber hoses for the vaccum advance on the tranny and the hoses will loose there strength cause of the heat and they will collapse and not get proper vaccum through. thats my 2 cents
01-28-2004, 08:23 PM | #23 |
Its 2-3 inches of rubber line to the manifold, 2-3 inches or rubber to the modulator. The rest is all metal. I am going to remove the metal line tonight and see if anything is stuck in there and give it a good cleaning.
01-29-2004, 01:46 AM | #24 |
Ok here is a pic of the setup behind the carb. Its a 3/8 nipple in the manifold with a 3-4 inch piece of 3/8 tube going into a 3/8 and 1/4 tee. The 1/4 tee is connected to the metal tranny line going to the modulator. Is it ok to tee this off? Not sure why it was done this way.
Thanks |
01-29-2004, 02:04 AM | #25 |
My other Love
hm is that connected to the back of the carb, Id much prefere to connect it to the nipple on the back of the intake manifold in the same place where the brake boost is connected
