Old 01-27-2004, 08:31 PM   #1
krazy_texan
krazy_texan's Avatar
trans?
well sorta i need to know how to support the back of the engine while the transmission is out of the truck. thanks guys
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-27-2004, 08:45 PM   #2
1972C10
1972C10's Avatar
Put a floor jack under the oil pan other than that i dont know of any methods
Why do you need to support it? I normally just let them hang while the trans is out
1972C10 is offline   Reply With Quote
Old 01-27-2004, 08:56 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A bottle jack with a 2X4 protecting the pan is the best way.
If you just let it go, you run the risk of breaking the exhaust manifolds, or stressing the welds on the headers.
Old 01-27-2004, 09:44 PM   #4
Chevy67Tk
Chevy67Tk's Avatar
A ratchet strap from frame rail to frame rail works also and is nice if you have to move it during the swap
Chevy67Tk is offline   Reply With Quote
Old 01-27-2004, 09:57 PM   #5
70short/step
70short/step's Avatar
Remember, if you have a V8 there isnt much room between the firewall and Distributor. Remove the cap or the whole distributor before the engine is dropped any when the tranny is removed to avoid damage to it or the firewall! Good Luck! 70short/step
70short/step is offline   Reply With Quote
Old 01-28-2004, 12:33 AM   #6
Longhorn Man
To add to my last reply, if you were to just remove the manifolds/headers to prevent damage, then you would tear up your motor mounts.
Old 01-28-2004, 01:54 AM   #7
1972C10
1972C10's Avatar
Ive never ran into any problems Friend of mine owns a transmission shop he never supports the engine either. I guess some have different luck Or worn out motor mounts.
Old 01-28-2004, 02:10 AM   #8
Longhorn Man
Happened to a member's truck in a tranny shop about 2 years ago, happened to me once (bought that way), and once at the shop on an E-250.
Old 01-28-2004, 02:23 PM   #9
smokekiki
Mike
smokekiki's Avatar
It only takes bad luck one time to ruin your day,or a shops reputation.Why take the chance?A buddy of mine that owns a trans shop would have a fit if one of his employies would let the motor hang.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
