Old 01-28-2004, 04:16 PM   #1
Castiron9
72 LONGHORN OWNER
Castiron9's Avatar
Speedometer question
Changed speedometer cable,,,,as it had a funky aftermarket cruise control set up.........Speedometer did not work before and it still does not work........Lubed cable as per instructions so what should I look at next Thanks.............
72-SUPER CHEYENNE/20 LONGHORN
70-C/30 DUALLY
Castiron9 is offline   Reply With Quote
Old 01-28-2004, 06:08 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Do you have the cable all the way on the speedometer? If it is a slip on connecion you have to press pretty hard to get it to go in.
Double check the connection at the tranny too.
If not, your speedometer may be fubar.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-28-2004, 07:37 PM   #3
Green72GMC
Green72GMC's Avatar
pull the cable out of the transmission and see if it has a plastic gear on the end of it, or inside the transmission. The gear will look kind of like this:
======[teeth]=
If you aint got one, that is what you need, I was only able to get one from the gm dealer.
1972 GMC SWB, 305 powered
1980 diesel VW pickup, Needs a Heart Transplant
1997 Toyota Taco
The Second Amendment is in place incase they ignore the
others.
Green72GMC is offline   Reply With Quote
Old 01-28-2004, 08:11 PM   #4
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
just like green 72 said. the gears are kinda pain in the butt to gett. There color coordinated so when you go to the dealer to get one they'll ask you which color it was. But if you ain't got one to begin with how do you know which color it was???
WRMZ71 is offline   Reply With Quote
Old 01-29-2004, 12:32 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Pull the cable off the speedo, and pop it out from under the dash so you can see it from the drivers seat while driving.
Go around the block and see if the cable is spinning. If it is spinning, you need a speedo. If it is not spinning, then you need to look at the add on cruise controll (does it work?)
Old 01-29-2004, 01:51 AM   #6
71swb4x4
71swb4x4's Avatar
The color coordinates with your tranny (or transfer case if 4x4) and your rear axle ratio. So if you know those then you don't need the color.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-29-2004, 04:43 AM   #7
jimfulco
www.novaresource.org/speedo.htm
www.novaresource.org/speedo2.htm
http://www.tciauto.com/components/speedometer_gears.htm
jimfulco is offline   Reply With Quote
