Old 01-28-2004, 04:28 PM   #1
gerry giordano
gerry giordano's Avatar
Will a 307 tow OK?
I'm looking into a C-10, '68 307, 4 spd manual. No modifications from stock I'd like to keep it pretty much stock and original so I'm not interested in a high performance engine. However, I do tow a light boat trailer- 1500 lbs or so. My question to you is will this do well towing? By way of contrast, I currently tow with 91 Caprice wagon with 305 automatic. Slow accelleration and slows a bit on the steep grades. So, better, same, or worse?
Thank you.
PS a guess a miles per gallon (not towing) would be apprciated too!
gerry giordano is offline   Reply With Quote
Old 01-28-2004, 04:31 PM   #2
cdowns
cdowns's Avatar
i'd think it would be about the same maybe slightly better with the manual tranny
Old 01-28-2004, 04:34 PM   #3
1969 GMC
1969 GMC's Avatar
the 307 should handle that just fine. you will probably get ~15 mpg if you really keep your foot out of it, but both of these depend on axle gearing too. If its 3.08 you will have a harder time towing but will get better mpg unloaded, etc.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-28-2004, 04:48 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
Those motors have a fair amount of torque. When my K20 had it's 307, I could easily haul around more than 100 bales of hay on a trailer. My K20 does have 4.56 gears though. Your 4 speed should be a granny low tranny that will easily get a heavy load moving.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-28-2004, 05:22 PM   #5
68 Suburban
68 Suburban's Avatar
1500 lbs is not a lot of weight. You should be fine. Mileage will depend a lot on what rear end you have in your truck.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 01-28-2004, 05:47 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
That truck almost certinally has 3.73 gears....i would say you would be OK. That low first gear will help out alot when taking off with a load.
I would be more worried about 4-wheel stock drum brakes than the engines power
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 01-28-2004, 06:42 PM   #7
67chevemall
67chevemall's Avatar
Gas is a %^&$# ! But it should tow 5000pds no problem!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-28-2004, 06:56 PM   #8
68 Suburban
I have towed 6000lbs + up and down mountains with drum brakes and have had know problems. Just make sure your drum brakes are well maintained.
Old 01-28-2004, 07:01 PM   #9
lukecp
lukecp's Avatar
Of course you have those Kevlar pads on there
I've drove a '67 with 4-wheel manual drums...was a deathtrap, lol. If i had a drum brake truck i would either upgrade to a power disc setup, or the kevlar pads.
Old 01-28-2004, 07:38 PM   #10
68 Suburban
Kevlars are great, but the main reason drum brake trucks are consider death traps is because of the lack of maintenace. Most people have 35 year old fluid in the lines, the original brake springs, brakes out of adjustments. Maintenance is the key, not the kevlars. Kevlars are just icying on the cake
Old 01-28-2004, 07:46 PM   #11
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
A 307 will tow well, but I would be more worried about those rear coils. There preety shaky when towing or hauling.
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 01-28-2004, 07:53 PM   #12
gotmud
gotmud's Avatar
Ive got a 68 c10 with a 307 3 speed on the tree that my dad used to pull stumps out of the ground and fields down in South Georgia. Soil was a sandy loam mixture.
Glenn
Cumming, Ga
(68 C/10 Fleetside LWB 307
(64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty)
(2001 Porsche Boxster S - 168 MPH of fun)
(2005 Chevy Avalanche Z71 1500)
gotmud is offline   Reply With Quote
Old 01-28-2004, 08:19 PM   #13
Eddie H.
Eddie H.'s Avatar
My 69 GMC came with a 307 originally. My dad used it for 20 years working on a farm towing and hauling everything
from hay bales to overload cotton trailers. It's a good little engine.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-28-2004, 08:41 PM   #14
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
I dont think youll have any problems. And i actually like my drum barkes. I would like to have discs, but i hear they might have more power loss than drums, because for a disc they are constantly on the rotor. Any body have results of this?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-28-2004, 09:09 PM   #15
lukecp
lukecp's Avatar
Drums also always have shoe-to-drum contact if they are properly adjusted. I think they have a bit less parascitic than discs though.
Every automaker has converted to disc brakes, and if you drive a new truck with 4-wheel discs you will want them too, hehe. Of course drums aren't too bad when properly maintained and upgraded
Old 01-29-2004, 12:25 AM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Rear discs are a waste of time and money IMO, I have done a drum to disc conversion in a car once. THe drums were marginal, and the disc set up worked perfect. The difference was only a foot in 60 - 0....a few feet 100 - 0. I understand that a foot could be the differance of crapping in your pants and bleeding in your pants, but it just seems like a whole lot of effort and cost for nothing much in performance.
Anyways, to the question at hand, acording to the GM papers, the 307 is rated to tow 6000 pounds with the 3.07 gears, 8250 pounds with the 3.73 (which you probably have as stated above) and is rated to tow 8700 if you have the 4.11 gear set.
Old 01-29-2004, 01:53 AM   #17
Hooter
My other Love
Hooter's Avatar
drums on a truck with a 500 horse 454 is not fun at all, I am soo glad I switched to discs
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
