Old 01-28-2004, 06:13 PM   #1
beaterC10
Lightbulb Stuck Shackle Bolt
I am trying to finish a flip kit install on my 84 1/2T. I thought while I was at it I would install poly bushings in the shackles and springs. I have everything apart except for the removal of one rear shackle bolt. It seems to be frozen into the sleeve of the shackle bushing. The other shackle bolt was frozen as well, it took nearly forever with a sawzall and grinder to cut the bolt and get the shackle out. The swazall didn't have much effect on the factory grade 8 bolts.
I have tried pushing the remaining shackle bolt with a 4T bottle jack braced against the other side of the frame and using a section of pipe to push against the bolt with the jack. That doesn't work either.
Any other ideas?
This project seemed like a good idea when I started. Now? I'm driving a Mercury Grand Marquis while my truck sits in the garage. That's tough on a guy.
beaterC10 is offline   Reply With Quote
Old 01-28-2004, 08:51 PM   #2
special70gmc
special70gmc's Avatar
i torched mine out, i did the same as you and not one bolt came out it sucked!
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 01-28-2004, 11:03 PM   #3
beaterC10
Hey at least now I don't feel so stupid. I had an 83 where the bolt came out with no problems. Must be something to do with living in the rust belt.
Old 01-29-2004, 12:20 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
You need to or maybe
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
