![]() Join Date: Nov 2000
I have a chance to buy a 9" rear off a late 70's ford f150. Would that be an ideal rear for my 72? Would I have to change the axles out to match my bolt pattern???Thanks in advance
I think most nine inch truck axles had 5 on 5 1/2 bolt patterns if i remember right. You can take the axles to a machine shop and they can weld up the old bolt pattern hols and smooth the face back down on a lathe and redrill the axles to your bolt pattern.
Just a little crazy 1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i. |
measure it
I think I would measure that lug pattern. A lot of ford 9" rears are actually 5x5. Don't know about the 70' f150. If you are unsure how to measure it PM me and I'll tell you how.
Tom |
Wiseass secured himself a BAN
12 bolt rearends are just as strong. Why change?
#5 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
if youre going to race and such, ford 9inches are alot better and stronger.
from what ive heard, most 9 inches are 5x5
70 longbed 496/th400/Ford 9" |
You guys are probably right. The only stock nine inch i've ever messed with was a 5 on 5 1/2 and everyone was saying that that was a common bolt pattern. Thanks for correcting me. I use an aftermarket nine inch in my racecar now. As far as strength, the 9 inch usually is stronger plus if you break an axle in a nine inch it won't come out of the housing, the only was the wheel will come off is if you break it at the outside flange.
Back from the Dead
I asked my neighbor about why most racers uses Ford 9" rears. He said he used them back in the day because you could swap out a set of gears really fast if you had to. Or you could have two sets, lower gears for in-town driving and a set of highway mileage gears? Just my $0.02
The only Carb that matters to me is the one under my hood! Salem, Oregon |
TOTY 2006
![]() Join Date: Dec 1999
Go get a ford 9 inch from a 70-75 Lincoln Continental. Look for the one with rear disc brakes, and it will have a lug nut pattern of 5 on 5. Gearing is most likely 3.00:1. That can be changed.
i used the same kinda rear axle your looking at, they are a 5x5.5 pattern. I had to narrow mine and i also had moser axles made for it, i redrilled my own drums.
The late 70s 9 inch will have 5 on 5 1/2 and the axle from backer plate to backer plate will be like 60 inches its a tad wider than the chevy rear ends
9"s are great for the fact you can have two hog heads one wil full spool and super low gears for racing and one with a locker or posi for driving with decent gears. Parts are cheap for them they really have alot goin for them Might try to locate a 28 spline 9 inch there the perfect width for chevy trucks. |
A Ford 9" takes 5-8 more horsepower to drive than a 10 or 12 bolt
Chevy rear end !!!!!! |
#13 | |
Ive never heard that one before What would cause it to use more horsepower? |
#14 |
Large Member
![]() Join Date: Jun 2002
pinion angle is what causes it..
#15 |
That is true about the Chevy rears, they take less horse power to use than the Ford 9in. Thats why most nascars use 9in housings and customs made 12 bolt center pumkins drops outs. Moser makes the center pumkins I beleive.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect. |
#16 | |
Ive seen them 12 bolt chunks in summit or jegs them things were high dollar |
