01-28-2004, 09:03 PM | #1 |
NEED HELP: How to change ignition lock cylinder
Hi all, I was wondering if anyone could tell me how to change the ignition lock cylinder on the steering column of a 77 chevy pickup.
I have removed the steering wheel, took out the turn signal mechanism, but have not a clue as to where to go from here. All help would be greatly appreciated! Thanks, Kevin |
01-28-2004, 09:15 PM | #2 |
there should be a couple of pins you can see there to pull out or those torx head screws.. i believe on the 77s tho it was a couple of pins
01-28-2004, 09:30 PM | #3 |
Do not see any pins
I looked very carefully, and I don't see the pins you are talking about. I even took the four bolts out of the upper column and slid it back, and I still can't figure out how to remove the lock cylinder.
thanks, kevin |
01-29-2004, 05:09 AM | #4 |
Some Chevy's have a vertical slot (sometimes covered with casting flash) in the upper right quadrant under the switch
where you insert a screwdriver to push a hidden latch. |
01-30-2004, 03:24 AM | #5 |
LED King
try this site: http://home.t-online.de/home/O_Scholz/steering.html
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
01-30-2004, 03:42 AM | #6 |
Professional Grade
Follow the above tutorial, very very useful!
If you still can't figure it out, give me a PM and I can help you out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
