01-28-2004, 11:03 PM | #1 |
need advice quick!
i was changing the spark plugs on my engine and i was putting in the last plug when i accidentaly screwed up the threads on the engine. What should i do to fix it. I didnt screw up all the threads. I felt it turning kinda hard so i backed out the plug and it only screwed up like the first thread. So would i be able to just get a tap and fix the threads. And can i just leave everything together, or do i need to take the head off to do it. any help would be appreciated. I need to get this thing running soon as it is my daily driver.
thanks, 67pro-street |
01-28-2004, 11:07 PM | #2 |
Watch out for your cornhole !
Get a thread chaser at the parts store. It's kind of like a tap. It just fixes little boo-boos like you have. No need to remove the head.
01-28-2004, 11:07 PM | #3 |
I'd say pull the head
67 C/20 camper special 350 |
01-28-2004, 11:10 PM | #4 |
Designated A-hole!
Fill the grooves on the thread chasers with grease to catch any metal shavings.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-28-2004, 11:10 PM | #5 |
You can use a tap, just make sure it is the same thread as your spark plug, try it in another hole first too. before you tap it put grease on the tap to catch the shaving. Do it very slow and carefull.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
01-28-2004, 11:18 PM | #6 |
i agree with TX. you a chaser instead of a tap. the tap will cut the treads more where a chaser with just clean them up. the tap could cut them too much and could cause a problem. also there is a special chaser and tap for some plugs because some tapper. i can`t remember if the car heads are but i know harley heads are. be carefull and definately put grease on the threads of the chaser.
Anthony |
01-28-2004, 11:24 PM | #7 |
thanks a lot fellas. I really appreciate the help
01-29-2004, 09:14 PM | #8 |
Agree....A Chaser with lots of greese.
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
