Old 01-28-2004, 11:14 PM   #1
68c10owner
68c10owner's Avatar
need help with pwr steering conversion fast
i started converting my 68 to power steering and ran into a few problems. first, the rag joint is a different size on the pwr box. obviously there is 2 sizes, right? also, what is the easiest way to get the column to collaps? the pwr box is longer and my column doesn`t want to give much. how much shorter does it need to be? finally, when i positioned the new box up on the frame, the front bumper bracket seems to be in the way. is there a different bracket or what? the power box is off of a 71 so i figured it would be a bolt on deal but it hasen`t been so easy. any help would be great. thanks
Anthony
68c10owner is offline   Reply With Quote
Old 01-28-2004, 11:18 PM   #2
dinnut
dinnut's Avatar
there is a diferent bracket for power steering. thats about all i can help you with
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-28-2004, 11:27 PM   #3
68c10owner
68c10owner's Avatar
a different bumper bracket? will only 67-68 brackets fit or can i use the one from the 71?
Anthony
Old 01-28-2004, 11:38 PM   #4
Rod
Your front drivers side outside bumper bracket may be for 67-68 non-ps trucks, they are not dimpled for the different Power steering box .. they are dimpled to allow clearance of the ps box. You could get away with using a ps type front outside bumper bracket from 67-72 gmc or a 67-70 chev 2wd putside bumper bracket. You could leave the outside bumper bracket off till you got one.
rag joint size should be the same PS or not.
collasable mid column shafts will collapse... there is a 67 version that dosent collapse..maybe you have that.... the shafts collapse pretty easy... even pounding it from the bottom while its still mounted will collapse the shaft... basically there are two plastic shear pins in the collapsable shaft
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-28-2004, 11:47 PM   #5
Rod
pic
Old 01-28-2004, 11:58 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
You shouldn't have to colapce the steering shaft. I have converted many 67-68 trucks with the single piece steering columns to power steering using the power steering gears and have not had to colapce any of them. The rag joint assemblies are different for the power steering gears and yes I do have Genuine GM ones in stock. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-29-2004, 12:00 AM   #7
Blue Beard
Blue Beard's Avatar
What year is the box you put in, and what did it come out of ..........?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-29-2004, 12:01 AM   #8
Classic Heartbeat
If you look at the input shaft on the manual gear you will see that it is longer than the one on the power steering gear. The overall length of the two gears are the same.... WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 01-29-2004, 12:06 AM   #9
68c10owner
68c10owner's Avatar
the box is from a 71 1/2 ton just like my 68. Wes, the power box input on mine is longer than the manual one. i put the box up where it needs to be and the shaft was way to long. i got it to move some but not enough yet. i got to keep working on it. how much do you sell the rag joints for? got any used bumper brackets for pwr steering?
Anthony
