01-28-2004, 11:34 PM | #1 |
Back from the Dead
Fuse Panel Help...running out of options
I am running out of places to wire into my fuse box under the dash. I'm looking for a permanent spot to run my Compressor to for my Airbags. I've already got my stereo and Airbag switches hooked up to it. I need a spot thats hot only when the ignition is in the "ON" position. Any ideas? I've got a temp spot for it but I'm looking for something more permanent.
The only Carb that matters to me is the one under my hood! Salem, Oregon |
01-28-2004, 11:37 PM | #2 |
you might want to run a relay from the battery to power it.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
01-28-2004, 11:52 PM | #3 |
Self-proclaimed LED man
try making a splitter. and unhook things like glove box lights, and cigaratte lighters. These are what i would suggest.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
01-29-2004, 12:01 AM | #4 |
Back from the Dead
Any idea which ones those are on the panel since most aren't labeled?
01-29-2004, 12:04 AM | #5 |
Should be able to trace the cigerette lighter back to the fuse box....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-29-2004, 12:11 AM | #6 |
its all about the +6 inches
Your best bet would to get a small aux fuse panel, and run a relay to the battery, and use one of the IGN UNFUSED terminals to turn on the relay.
01-29-2004, 12:12 AM | #7 |
I believe that the cigarette lighter is hot all the time, not switched. Not a good idea for your compressor.
72 C10 Cheyenne Super Full trim Factory tach dash A/C dash Factory tilt 350 / 350 power train - with Edelbrock components. |
01-29-2004, 12:14 AM | #8 |
andy I did not give you permission to use my photo I made. That will be $2.00 please. Make check payable to Cash. lol j/k
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren http://www.myspace.com/dmurphy68 |
01-29-2004, 12:14 AM | #9 |
Keep On Truckin'
Longhorn Man
Thanks for that GREAT picture and labeling. That's really going to help me. Beats the heck out of wiring diagram that's 30 yrs old.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
01-29-2004, 12:15 AM | #10 |
Keep On Truckin'
dmurphy68
Well, thank you too dmurphy!!!
01-29-2004, 12:16 AM | #11 |
i have a question about the ign unfused. what exactly is it? is it just a port with no fuse? can you put some thing on each of those little prongs? like.... i need to find a place to put my new hei wire.... where should i wire that in? im thinking im not supposed to run it off the pink wire going to the starter.. would it be bad if i spliced it into that wire?
70 longbed 496/th400/Ford 9" |
01-29-2004, 12:18 AM | #12 |
It is just a nother spot to put extra things on. they are hot with the ign. If you use them i would put an inline fuse there
Darren
01-29-2004, 12:30 AM | #13 |
CONVERT IT TO 220 VOLT 60 AMP
THAT SHOULD DO IT......DOHOOO |
01-29-2004, 01:21 AM | #14 |
if i wanted to run my hei wire from the ign unfused slot would i need to run an inline fuse or a ceramic block or something?
01-29-2004, 01:26 AM | #15 |
Fues or fuseable link.
01-29-2004, 03:17 AM | #16 |
you should run probally at least #8 wire to most compressors that are fused and also through a relay that is only hot when ignition is on. and cycles w/ psi switch.just remember bigger the compressor bigger power wire needs to be.
01-29-2004, 07:19 AM | #17 |
English Chevy Owner
Try this, I'm going to add an extra fuse box that's switched, painless sell a kit but it's pretty pricey and you can do it yourself much cheaper.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
01-29-2004, 08:39 AM | #18 |
Hey Phil,
Nice schematic! Do you charge if we repost the pic? Jim |
01-29-2004, 09:50 AM | #19 |
English Chevy Owner
Yep, send all your unwanted truck parts (particularly if they're a complete drum/drum power brake booster setup and a front swaybar and brackets) to ............(may cost you a little bit on shipping to get them over the Atlantic to me)!
Please post away, would be great if someone could add wire gauges for you guys as we use metric over here ( I would use for the power wire 4mm for 39 amps or 6mm for 50 amps, thinwall cable and the switch circuit doesn't need to be anywhere near as big as it takes very little current.)
01-29-2004, 10:48 AM | #20 |
lol
