Old 01-29-2004, 10:02 AM   #1
JJR
JJR's Avatar
Van Vs Truck Bucket Seats
I know this probably has been covered before but I wanted to check. I was at the local Pull-A-Part yesterday and they were just sitting out a 71 1-ton Van/Camper. It had a set of mis-matched low rise buckets. One with a squared off top and one that had a little taper toward the top. Are the buckets used in Vans the same as the Trucks? I would assume that the support brackets are different but did not know if the seat itself would be the same. Thanks.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 01-29-2004, 12:50 PM   #2
JimKshortstep4x4
Talking
All of the truck/Blazer seats that I have seen have rounded corners at the top and the vans are squared off. I have seen Dodge vans with what looks like the right seats. In both vans the brackets are completely different.
Jim
