Old 01-29-2004, 10:54 AM   #1
Truckstr
Truckstr's Avatar
Exclamation Instrument panel lights are out...
I thought it was the switch (headlight), but I replaced the switch and... still nothing.
I recently replaced ALL of the wiring (forward light harness, engine harness, dash harness, intermediate rear harness, rear harness) and all was working fine for about a week. All of a sudden I pull the lights on one evening and... no dash lights.
All of the bulbs are fine. All of the fuses are good. The electrical gauges work fine (battery, temperature, fuel level). Everything esle works fine... except the dash lights.
I'm ata loss. Anybody have any good ideas? Thanks in advance.
This is on my '67, BTW.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 01-29-2004, 11:32 AM   #2
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
re
although it's not likely, it could be the printed circuit panel on the back of your dash panel. What you might want to try is unplugging the electrical connector on the back of the dash panel and checking for voltage at the connector (and rotating the rheostat to watch the voltage climb or drop). If you have voltage present then you have a dash problem, if you don't have voltage then maybe you have trouble at the fuse block. You should be able to find a schematic for your truck in the FAQ section of this board. Hope this helps, TJ
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
Old 01-29-2004, 11:34 AM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Check your tail lights, more than likely you have a blown fuse or a bad connection in that circuit, may have a wire rubbing the frame?
Turn the dash dimmer on your switch?
sneakysnake is offline   Reply With Quote
Old 01-29-2004, 01:16 PM   #4
Truckstr
Truckstr's Avatar
The headlight switch is brand new and yet the same condition exists as with the old one. I played parts changer on the switch knowing that the old one sqeaked pretty bad when I turned the rheostat.
Again, all of the fuses in the fuse block test good.
This is brand new wiring from M&H Fabricators and was a plug and play deal.
I installed a new dash bezel and transfered all mof the old gauges into it. Still the same condition - no dash lights.
The printed circuit looks really good.
Help!
Jeff
Old 01-29-2004, 01:22 PM   #5
1971LT1SWBPOSI373
re
he's a link to the wiring diagrams:
http://www.geocities.com/chevroletc1070/wiringdias.html
Drinks Miller MGD
Old 01-29-2004, 02:07 PM   #6
sneakysnake
Your gonna have to break out the volt meter
check voltage to the bulbs, you may have lost your ground, check your plug to printed board,and plug to body ground.
Old 01-29-2004, 02:12 PM   #7
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Pull your gauge cluster and check your printed circuit for continuity with a multimeter (don't just look at it). If that is good, check the harness plug (as said above) for voltage.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-29-2004, 02:36 PM   #8
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
ground, i done had this problem
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-29-2004, 02:53 PM   #9
1971LT1SWBPOSI373
re
you can also clean the printed circuit plug contacts using a pencil eraser while your there.
I'm in the process of rebuilding my dash panel, last night I threw out a bulb holder because for some reason it wouldn't make contact with the printed circuit. I had a good bulb but couldn't get continuity with the meter.
A quick check for a bad ground would be to put a jumper lead with the alligator clips between your dash panel and a good ground. If that doesn't work then you'll have to pull the dash panel and check the wires.
If you don't know which wires the check on the plug don't worry. Just look at the printed circuit, you can see the 4 bulbs that illuminate the guages. Trace the circuit to the connector contacts and you'll have it, the circuit is in parallel through all 4 bulbs.
Hope this helps, TJ
Drinks Miller MGD
Old 02-01-2004, 01:45 AM   #10
starbuckk
Had this problem and was a number of things all at once.
1. Headlight switch (you already checked that).
2. Bad ground.
3. Connection INTO the fuse box was bad.
starbuckk is offline   Reply With Quote
