01-29-2004, 11:04 AM | #1 |
Power Windows
Alright. I have power windows in my truck with the wires coming from the window motors just hanging there. Where do I run these wires? any pics would really help. thanks all.
01-29-2004, 01:23 PM | #2 |
If it has factory power windows there should be a wire harness in the door that runs to the motor and to the power window switch on the door panal which should have the mating connectors on them. If they were aftermarket you will have to run a power feed and ground wire. The wires should come threw the cab wall and into the door threw a corrugated black tube. Don't forget to put a fuse in line if you have to wire them. Power should be available at the fuse box as an auxilliary slot or you can tap into a known live wire for feed power.
