Old 01-29-2004, 12:44 PM   #1
Jwill41
Jwill41's Avatar
pinion angle
I am getting ready to change the rear end in my 67 gmc that has leaf springs. I need to relocate the spring perches. How do I measure the angle to be sure I have it correct?
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 01-29-2004, 02:21 PM   #2
fatfords
fatfords's Avatar
Jwill41,
When I did this, I levelled the rear and put a bubble level on the saddle pad. Then put a magnetic protractor across the flat surfaces of the third member yolk and read the angle. You can pick up a magnetic protractor for $10-15 at Home Depot.
Good Luck!
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 01-29-2004, 05:59 PM   #3
1972C10
1972C10's Avatar
I use one of them magnetic base angle finders it works great set it on that flat pad on the pinoin houseing and set it up anywhere from 3-5 down
1972C10 is offline   Reply With Quote
