01-29-2004, 08:48 PM | #1 |
How much lift on 87 2wd 1/2 ton
I'd like to lift this thing a little so its not ridin so low. How many inches are good just for looks without making it look to odd? Has 15" tires, so I don't want to go real high cause the wheel wells won't be filled out. I found a lift kit in JC Whitney that was fairly inexpensive, but it didn't say anything about needin different shocks or changin hoses. Would that be right?
1987 GMC 1500 5.7L 1985 Chevy 3/4 4X4 2001 Chevy 2500 HD 4X4 2007 Chevy 3500 Duramax 4X4 |
01-30-2004, 03:24 PM | #2 |
you can run 32" at stock height.. it fills the wheels wells real well and gives a bit more ground clearance. Feel free to check both my sites... one for my truck.. other for "prerunners"..
you can do a body lift if you are just wanting larger tires. if you are wanting a bit more suspension.. you could go with blocks in back. and either a coil lift or a coil spacer. If you want more info on this subject matter feel free to ask.... i will do my best to answer it...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
01-30-2004, 05:57 PM | #3 |
driving is in my blood
You should give a 2wd a 5" in front and 6" in back negative lift IMO
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-30-2004, 06:25 PM | #4 | |
I upgraded my 86 2wd LWB from the standard spring set to the heavy duty "camper special" springs. The springs came off of my '77 donor truck. I like the look even this small lift of about 1 1/2" gave me. Someday maybe I'll lift it a little more, but for now at least it looks a little more like a truck should....right Prerunner??? |
01-30-2004, 08:49 PM | #5 |
i threw 3/4 ton springs in the back of my 76 and she sits nice now i gotta figure out what to do with the front cause she sits on a heck of a slant
01-31-2004, 06:12 AM | #6 |
Zilverado... you are correct... a stock truck with the stock 235s... looks awfully funny.. should have come with 31s from the factory.. larger tires make a big difference alone.
rolson, did you put the 3/4 ton springs on the front too? try 1-tons? the PO put what he called on the build sheet HD front coils.. my truck has NO rack.
