01-30-2004, 01:48 AM | #1 |
Garage Queen Material
ignition stuff?
what is a good performace one to get?
i was planning on getting: MSD Pro-Billet Street 6AL ignition box blaster2 coil but to cut some costs back, so i can get the motor running faster, i think it would be best to go with a regular HEI probably, and get the 6AL box later on. which distributor would be good for under $200? |
01-30-2004, 02:05 AM | #2 |
01-30-2004, 02:05 AM | #3 |
Gentleman Jim Driver
If you're planning on upgrading later anyhow, why not clean up the one off of your 305 and save the $200 for what you really want?
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
01-30-2004, 02:09 AM | #4 |
you should be fine with a standard HEI. since you dont have anything totally radical, it should produce enough voltage. the 6AL box could also be a good upgrade with all of the features it offers. Joe, his stock HEI wont work because he is eliminating the ESC system, just like i did.
01-30-2004, 02:20 AM | #5 |
check mikes site i think it says how to eliminate the esc with the stock dizzy
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-30-2004, 02:21 AM | #6 |
oh i guess i ment jeffs site
