01-30-2004, 05:35 AM | #1 |
go bucks!
difference between a .....
pwr. disc brake booster w/it's bracket and master cylinder, and a pwr. DRUM brake booster and it's bracket and master cylinder? do the holes all line up on the firewall between the two? and lastly,... is it possible to put pwr.to the drum brakes and still use the non-pwr. brake lines? any info. on this subject is appreciated!
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
01-30-2004, 05:41 AM | #2 | |
Re: difference between a .....
Just sitting here contemplating contemplation. |
01-30-2004, 10:50 AM | #3 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-31-2004, 04:03 AM | #4 |
go bucks!
thanks both to cpne and 68suburban!
01-31-2004, 04:06 AM | #5 |
go bucks!
forgot to ask also......is there a diff. between a pwr.disc brake booster and a pwr. drum brake booster? in other words can i use a disc booster for my drums,and make it power drum brakes... can the wheel cylinder handle the added pressure? can't remember if there is a specific difference between the 2 wheel cylinders.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? Last edited by BUXMAN66; 01-31-2004 at 04:08 AM. |
01-31-2004, 06:38 PM | #6 | |
go bucks!
01-31-2004, 06:55 PM | #7 |
Careful, they attack...
The booster shouldn't matter, it's the master cylinder that is different. You can't use a disc master cylinder on a drum setup and visa versa. The wheel cylinders should be the same. They will handle the power assist no problem.
01-31-2004, 10:08 PM | #8 |
go bucks!
how about putting my master cylinder from my present drum set-up,onto the disc's power booster?there's a pwr. disc brake booster/master cyl. on e-bay just wondering if i can make it work on mine.
01-31-2004, 10:55 PM | #9 |
The main difference is in the proportining valve in the drum or disc application. Pretty much you could get away with either master cylinder on a drum or disc booster.
Use the right proportioning application valve though.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
01-31-2004, 11:21 PM | #10 |
My other Love
the boosters are exactly the same
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
02-01-2004, 07:00 PM | #11 |
go bucks!
thanks for the info. rod,hooter! i'll be looking for a pwr.drum brake prop. valve then!
02-01-2004, 07:57 PM | #12 |
The drum setup doesn't have a prop valve. If you have manual brakes, you can use your valve. It's a combo valve only. Not pressure difference from front to rear. I did it on mine when I just added a booster. I had manual drums, and added a booster. No changes necessary.
02-02-2004, 12:51 AM | #13 | |
go bucks!
02-02-2004, 01:30 AM | #14 |
So what would happen if you switched from drums to discs without using the proportioning valve but just changing the master cylinder??
Just a little crazy 1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i. |
02-02-2004, 02:06 AM | #15 |
My other Love
the front and bacl brakes could lock up at different times, or the front brakes could lock up right away and th back ones could not even inguage, I would not try it at all, you are just asking for a serious accident
