English Chevy Owner
Setting up front wheel bearings
Hi,
Can anybody tell me what is the best way to set up my front wheel bearings as they have some play in them, I obviously didn't get them tight enough when I changed the front shoes. (Drums are still rivetted to hubs) Is there an easy sure-fire way to get this right. Thanks Guys
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
spin the drum while tightening the nuts to make sure the bearings are seated correctly remember that nut it holding your wheel on so it needs to be tight.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
English Chevy Owner
How tight is tight? Is there a reccomended torque figure for these?
I think its about 15 lbs. to seat the bearing, then back off to the nearest slot for the cotter pin...don't foreget the cotter pin!!
Erik
![]() 350/350 3.73 Next; 335hp GM Crate |
The way I set them up is to seat the bearings, make sure that they spin ok and then I tighten to the next slot to preload the bearings slightly. I recheck to make sure that the bearings are not too tight.
The tapered roller bearings work better with a slight amount of preload on them, otherwise if they are loose the rollers can skid which is not good. Peload insures the all of the rollers are in contact with the races. Jim |
