Old 01-30-2004, 08:36 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
tranny or u-joint problems
transmission? u-joints ?
I drive an 81 1/2 ton with straight 6 in it. I assume the transmission maybe is a 350. well when I put it in gear it makes a loud clunk noise. I thought ok look at the u-joints. I dropped the drive shaft. and I have not yet removed the u-joints from the drive shaft yet but the seals look good they are not dried out. the joints I grab in my hand while the joints are still on drive shaft and I have drive shaft on the work bench. I dont see any unusual movement from the u-joints. so I started the truck with out drive shaft in and shifted from reverse to drive no noise sounds good. but when I put it in park with the motor running it makes a noise that I dont like................ HELP
tphsmith is offline   Reply With Quote
Old 01-30-2004, 10:10 PM   #2
walker
walker's Avatar
It may be play in your rear gears. Jack the rear up and turn the pinion back and forth by hand to see how much play is in it.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 01-30-2004, 10:13 PM   #3
Deltaskier
What he said.
Deltaskier is offline   Reply With Quote
Old 01-30-2004, 10:22 PM   #4
Chevy67Tk
Chevy67Tk's Avatar
If your hearing a ratcheting sound when you put it in to park with the engine running and no drive shaft, that is the parking paw trying to engage on to the output carrier while it is still spinning. I wouldn’t do this too often, as there is a chance of shearing off the paw.
Chevy67Tk is offline   Reply With Quote
