Old 01-30-2004, 08:38 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
tranny???
transmission? u-joints ?
I drive an 81 1/2 ton with straight 6 in it. I assume the transmission maybe is a 350. well when I put it in gear it makes a loud clunk noise. I thought ok look at the u-joints. I dropped the drive shaft. and I have not yet removed the u-joints from the drive shaft yet but the seals look good they are not dried out. the joints I grab in my hand while the joints are still on drive shaft and I have drive shaft on the work bench. I dont see any unusual movement from the u-joints. so I started the truck with out drive shaft in and shifted from reverse to drive no noise sounds good. but when I put it in park with the motor running it makes a noise that I dont like................ HELP
tphsmith is offline   Reply With Quote
Old 01-30-2004, 08:51 PM   #2
JimKshortstep4x4
Talking
Is your drive shaft out when you are putting it into park? If it is the transmission is probably turning and it will make a bad noise.
Jim
Old 01-30-2004, 09:14 PM   #3
tphsmith
tphsmith's Avatar
drive shaft
yes the drive shaft was sitting on the workbench when I was shifting the tranny while the motor was running. so that answers that question about putting it in park while the engine was running and no driveshaft installed
